Home > Maintenance & Mods (L322) > Best "home" method for filling TD6 gearbox?
About to do an oil change on my Td6 gearbox. Lots written about changing it but can't find anything about how everyone actually got their oil in! I'll be doing it on the drive in off road mode so lying on back. The driveshaft seems to prevent easy access to the filler hole.
I was thinking of using an old ATF bottle and squeezing it in 1 litre at a time, or running a hosepipe down from the engine bay?
Any suggestions about previous successful methods welcome. .
Post #138907 1st Sep 2012 1:20pm
Re: Best "home" method for filling TD6 gearbox?
It won't work, you need something like this
Post #138914 1st Sep 2012 1:45pm
mjdronfield
If its any help, I ended up with my Discovery Td5 off the road for 4 days when I tried to change the gearbox oil on that.
No matter what I tried, I couldn't fill it up again. Restricted access etc etc......
Ended up ordering one of these ;
http://www.ebay.co.uk/itm/Laser-Multi-Purp...3f148dd044
and had to be off the road whilst it was delivered.
Do a few squirt tests with bottles before you drop your oil !!
Just my 2p. I know the Td6 may be different............ 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #138915 1st Sep 2012 1:46pm
mjdronfield
47p2 just beat me to it.
Been there - made that mistake...........
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #138916 1st Sep 2012 1:47pm
Thanks guys, it's going to be a long afternoon then Wink .
Post #138918 1st Sep 2012 2:13pm
SteveMFr
Site Sponsor
Hi Joe,
Hope it's not too late - these little pumps may be hard to come by right now as they are usually used for oil space heaters, but they only cost like €1-2 over here in the winter. And they work great on ATF.
Otherwise run a hose/funnel from the engine compartment - but get help or you'll make a mess.
And make sure the ATF temp is correct when checking the fill level. I can't remember if the AllComms shows live ATF temp - otherwise a cheap infrared thermometer on the pan works fine. Or you could get an IIDTool... Whistle
Rolling with laughter
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #138920 1st Sep 2012 2:34pm
Are you changing the filter Joe?
Post #138921 1st Sep 2012 2:43pm
@ 47p2
No, 'box has only done 25,000 miles so this is a precautionary service change as prescribed by the gearbox uber guru RRPhil Smile
@ SteveMfr
They're on eBay, worth a punt at £1.65 or £2.95
http://www.ebay.co.uk/itm/LARGE-SYPHON-MAN...27bf216e73
http://www.ebay.co.uk/itm/16-SYPHON-SIPHON...45fdb5a718
If these work well, they will also be useful for syphoning the ATF out of the 20 litre container Smile
Not sure why this one is £10 ?
http://www.ebay.co.uk/itm/HAND-SIPHON-PUMP...1c0fcd9d12
or
http://www.ebay.co.uk/itm/OIL-FLUID-EXTRAC...6rk%3D4%26 .
Post #138926 1st Sep 2012 4:18pm
You need to check the diameter of these pumps Joe, they could be too large to fit in the filler hole
Post #138927 1st Sep 2012 4:29pm
I've loads of plastic pipe and connectors so should have no trouble reducing down. You don't happen to know the size of the filler thread do you? I'm guessing it will be @ 1/2 inch? .
Post #138929 1st Sep 2012 4:32pm
This might be a more fun way of doing it Laughing
http://www.ebay.co.uk/itm/TRADITIONAL-BRIT...19d4d701a7 .
Post #138930 1st Sep 2012 4:34pm
VaguelyVogue
United Kingdom 2006 Range Rover Vogue Td6 Buckingham Blue
Gravity works fine Joe - I usually just siphon with the new oil can standing on a table at the side of the engine bay with some 10mm dia hose with a bulldog clip about 1ft from the gearbox end to stop the flow when needed. Routing is external. It takes about 45 minutes this way for the initial fill before cycling through the gears and then warming up the oil (so generally 2 further top ups). I use an old oven tray beneath the transmission to catch any excess oil.
Post #139005 2nd Sep 2012 8:27am
What make of filter have people used when changing the transmission fluid and filter in the TD6 gearbox?
Post #139007 2nd Sep 2012 8:36am
Joe,
Last time mine was done on my old TD6 they filled it using a large syringe thing... That was a tech in Stratstones...
Craig Thumbs Up
Post #139008 2nd Sep 2012 8:43am
I bought one of these for working on the Defender, to fill diffs etc. Dead cheap and really effective.
http://www.ebay.co.uk/itm/Draper-Oil-Sucti...500wt_1054 Discovery 4 HSE
Post #139012 2nd Sep 2012 9:31am
