Home > Maintenance & Mods (L322) > Air compressor |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
What valve are you talking about? What faults are you showing? Have you had your codes read? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
30th Aug 2012 9:41pm |
jay-p Member Since: 26 Aug 2012 Location: SELSTON / NOTTINGHAMSHIRE Posts: 46 |
On the end of the black part of the pump there's a white disc with two holes in for some kind of tool to rotate it, if its on the H setting there is more pressure on the valve inside. I've got air suspension inactive on the dash, I had it reset when I got the car 5 weeks ago, it worked fine for a few days then went again, one thing I thought of doing was leaving the heat sensor out of the pump head, this way it won't throw the overheat fault? I never use the height adjustment apart from it dropping itself on the motorway so I'm happy it's not oing to burn out or anything |
30th Aug 2012 10:24pm |
Jay
31st Aug 2012 6:28am |
Didnt bother taking the sensor out, although id assume that only sends a message when it gets too hot, I have read quite a few stories that the sensor can start to fail and give " too hot " signals before its actually too hot.
31st Aug 2012 11:36am |
Heres the valve I was talking about by the way -
31st Aug 2012 11:37am |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 316 |
Don´t let run the compressor in other fixings like at from the manufacturer, the both springs are adjusted in correct power. And don´t let run the compressor without the heat-sensor, and it is normal after your "refitting ", that the lamp is without function, so you MUST clear your fault wtih one of the 3 reset-tools..., you have changed the dryer and the pistonring??
31st Aug 2012 1:59pm |
I didnt replace anything just gave it a clean and re-assemble, the bore was not worn and the piston ring needed compressing slightly to get back in the bore so I think they were fine. What does the above spring / valve control? from what I can make out its just a relief valve, which would make sence if the spring was tired in the L position and causing the pump to struggle reaching full pressure? |
31st Aug 2012 4:17pm |
