Home > Maintenance & Mods (L322) > Air compressor
jay-p
United Kingdom 2002 Range Rover Vogue 4.4 V8 Zermatt Silver
Air compressor
I stripped my inactive pump down last night to find it looks fine, I used a little wet and dry in the bore and piston ring then reassembled with a little vacuum grease, as well as cleaning and regreasing all o-rings etc I then tried it with 12v and hey presto it sounds fine, my suspension has stayed at the same height since being unplugged 2days ago so I'm confident I have no leaks. So fingers crossed when it's back in and reset it should be ok. One thing I do want to ask about is the H M L settings on the back off the unit, from what I can assume this spring loaded valve is what holds the pressure? Mine was on L my only thought is maybe the spring was a little tired and letting pressure escape???? I've put it to H so only way to find out is get it reset and keep my fingers crossed, anybody else altered this valve?
Post #138641 30th Aug 2012 9:24pm
What valve are you talking about? What faults are you showing? Have you had your codes read? [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #138652 30th Aug 2012 9:41pm
jay-p
On the end of the black part of the pump there's a white disc with two holes in for some kind of tool to rotate it, if its on the H setting there is more pressure on the valve inside. I've got air suspension inactive on the dash, I had it reset when I got the car 5 weeks ago, it worked fine for a few days then went again, one thing I thought of doing was leaving the heat sensor out of the pump head, this way it won't throw the overheat fault? I never use the height adjustment apart from it dropping itself on the motorway so I'm happy it's not oing to burn out or anything
Post #138662 30th Aug 2012 10:24pm
Jay
Never heard of anyone doing that to the compressor. Taking the heat probe out might add other problems with the system not seeing a heat increase???? If you can get the codes read they should indicate what your problem is. They will help fix the source. Mine kept throwing a fault indicating a fuvked bag. Stripped the compressor and cleaned and greased and not had a fault since. That must be 2months ago. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #138675 31st Aug 2012 6:28am
jay-p
Didnt bother taking the sensor out, although id assume that only sends a message when it gets too hot, I have read quite a few stories that the sensor can start to fail and give " too hot " signals before its actually too hot.
Anyway its all back in, just need to get it re-set. I have noticed that there are no lights in the middle now on the inhibitor switch or the ride hide indicator, is this normal? They were on before I unplugged it?
Post #138754 31st Aug 2012 11:36am
jay-p
Heres the valve I was talking about by the way -
Post #138756 31st Aug 2012 11:37am
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Don´t let run the compressor in other fixings like at from the manufacturer, the both springs are adjusted in correct power. And don´t let run the compressor without the heat-sensor, and it is normal after your "refitting Wink", that the lamp is without function, so you MUST clear your fault wtih one of the 3 reset-tools..., you have changed the dryer and the pistonring??
Regards, Meerbusch L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #138794 31st Aug 2012 1:59pm
jay-p
I didnt replace anything just gave it a clean and re-assemble, the bore was not worn and the piston ring needed compressing slightly to get back in the bore so I think they were fine. What does the above spring / valve control? from what I can make out its just a relief valve, which would make sence if the spring was tired in the L position and causing the pump to struggle reaching full pressure?
Post #138815 31st Aug 2012 4:17pm
