Home > Technical (L322) > In the absence of a service manual...
Andy
Where does the air compressor relay go?
I ordered one a couple of weeks ago and now I've fixed my compressor, I need to fit this relay as is recommended.
Part no YWB 500220
Thanks in advance 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #137157 22nd Aug 2012 10:48am
I can't figure out how to lift images off the workshop manual but it apperes to be on the back of the EAS control module some where near or under the drivers seat . I know bit vague aren't I . 2008 MY Supercharged
Post #137162 22nd Aug 2012 11:10am
Andy
I'll have a look. thanks 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #137170 22nd Aug 2012 11:32am
Here you go, Item 4, adjacent to rear fuse board.
Post #137172 22nd Aug 2012 11:35am
DELETED, I still cant upload the pdf's but go to my gallery and they are there. 2008 MY Supercharged
Post #137173 22nd Aug 2012 11:37am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Accordng to Rave:
OPERATION
Power Distribution
Feed from the positive battery terminal (C0192) is supplied to fusible link 5 and fuse 57 of
the passenger compartment fuse box (C0632) on an R wire. Fuse 57 (C0582) provides a
constant battery feed to the air suspension ECU (C2030) on an RN wire. The air suspension
ECU (C2030) is earthed on an N wire.
Fusible link 5 (C0588) is connected to fuse 18 of the rear fuse box (C2024) by an R wire.
Fuse 18 provides a constant battery feed to the air suspension relay, which is also located
in the rear fuse box.
Post #137175 22nd Aug 2012 11:39am
Wiring Diagram.
Fuse 18 on rear board, relay is adjacent to it.
Post #137177 22nd Aug 2012 11:46am
I normally cheat and just take a screengrab Thumbs Up .
Post #137220 22nd Aug 2012 3:48pm
Andy
Cheers guys.
Replaced the relay but can't see what difference it's supposed to make? The dealer advised replacing it as and when I got the air compressor replaced. I've heard other sources say its recommended to change it but anyone know why? 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #137397 23rd Aug 2012 12:24pm
The new relay has been modified as the old ones had a tendency to stick on and burn out the compressor.
For the small cost involved in the relay it is worth changing
Post #137398 23rd Aug 2012 12:26pm
Simes
Belt and braces matey.
Could be that if the previous compressor was drawing excess current in in dieing days that the contracts could get burnt or pitted inside the relay - leading to high resistance and the new compressor running slowly or not at all.
Post #137399 23rd Aug 2012 12:29pm
Andy
Well the compressor isn't running as often. In fact I haven't heard it since the relay was fitted! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #137518 24th Aug 2012 8:36am
