Home > Maintenance & Mods (L322) > De-cat Td6 ?
Trying to look through a Cat is akin to sticking a Brillo pad into a piece of tubing, you can't see through but the air will go through.
Most vehicles from around 1992 will have had a Cat factory fitted, so if you do remove yours make sure you go to a friendly tester or you could fail
Post #136714 18th Aug 2012 9:21pm
