Home > In Car Electronics (L322) > Electric steering not working. |
daveym Member Since: 21 Aug 2011 Location: place Posts: 62 |
Has it gone into 'Transport Mode'? Are the footwell lights coming on? |
18th Aug 2012 4:06pm |
henry nelson Member Since: 09 Oct 2011 Location: carlisle Posts: 43 |
yes foot well lights are working, dont know about the transport mode.not a sat nav car and it does not have its own stereo in, ( information button stopped working) put my own stereo in. Do i need to get it put on a computer to check transport mode?. |
19th Aug 2012 5:32am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16284 |
Disconnect the battery again... Temperamental these RR's
19th Aug 2012 7:06am |
Is there a particular way to do the battery. |
19th Aug 2012 7:23am |
Make sure when you re-connect it you dont dab the battery terminal on and off several times... Try and re-connect in one movement...
19th Aug 2012 7:44am |
How long should i leave it disconected ? |
19th Aug 2012 1:33pm |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6408 |
Half an hour should do you. On reconnection start the car and turn steering wheel lock to lock to clear all dash faults (may need a little drive about too) .
19th Aug 2012 2:11pm |
Cheers Joe will try that on Tuesday, working nights this week. |
19th Aug 2012 2:32pm |
Ok have disconected the battery for 30 mins but the electric steering still wont wont work/or seat memory. Do i need to have it put on a laptop to check for a fault ect. |
21st Aug 2012 11:10am |
Um, fuses ?
21st Aug 2012 1:02pm |
The seat electrics still work apart from memory. Fuse 20 ok. Fuse 23 ok. |
21st Aug 2012 1:56pm |
Stumped ?
21st Aug 2012 3:19pm |
thanks Joe 90 i think it is diagnostics time. Cant think of anything i did differant the first time. Cheers HENRY. |
21st Aug 2012 4:08pm |
?? . Experience is the only genuine knowledge, but as time passes, I have forgotten more than I can remember Volvo V70 P2 2006 2.4 Petrol 170bhp Estate SE MG Midget Mk1 1962 Previous: L322 Range Rover TDV8 3.6 2008; L322 Range Rover TD6 3.0 2002; P38A Range Rover V8 1999 |
21st Aug 2012 4:58pm |
