Home > Maintenance & Mods (L322) > TD6 new 'vortex' type breather filter
mrblonde
United Kingdom 2003 Range Rover Vogue Td6 Adriatic Blue
Gents
Will soon be changing air filter so may as well fit the new 'vortex' type breather filter while im at it, wheres best place to get one from? I've searched on here but found more than 1 part number quoted
Cheers
Post #134495 5th Aug 2012 5:04pm
mjdronfield
I can see where you are coming from, the posts on the forum get confusing over part numbers.
My understanding is that you need to fit the newer BMW unit, which the Land Rover dealers never had. You will need to go to a BMW dealer.
You can replace the entire unit, or you can just replace the "element" part. I replaced the element part only, and have not had an issue. It is like a plastic cone shape. You never change it - gravity lets the oil drop on it, and it runs down and away.......there is nothing there to get blocked.
I didn't fit it myself - the garage did it whilst doing other stuff, and they said it just dropped straight in. ie there was no tab to cut or anything.
I understand that when others have done it, there may have been a tab, but you can take it off with a knife.....
I also understand the part is the same on the Td4 Freelander and 320d BMW's, but I have no proof of this.
The original foam based filter can get blocked and cause turbo failure amongst other things, if not chenged regularly. BMW redesigned the unit to just be like a plastic cone vortex, so can never block.
I think you can just replace the filter part, though you can replace the whole unit if you prefer.
The part number I saw for the whole assembly is BMW 11127799224 - I can't guarantee this, as I didn't do the whole unit.
For the filter/element only, its BMW part number 11127799367 "Oil Seperator" and that fitted fine. I guarantee that.
The entire unit is double the price, approx £20 for "element" or £42 ish for complete unit.
Hope this helps. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #134499 5th Aug 2012 5:19pm
ahebron
New Zealand
I have just ordered one off the Bay of E.
Including post iys UKPds 65.
Will report when fitted.
Adrian VW Amarok 2014 Highline auto
Post #134570 6th Aug 2012 8:00am
Fitted vortex cone filter in place of filter element today.
Straight replacement, vortex pops straight in after removing old filter element, no mods needed.
BMW number 11127799367 available from Here for anyone interested.
Straight forward 40 minute job for a dry day. Smile
Post #135731 13th Aug 2012 2:37pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
I got one too for £20 all in through the bay of e. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #135742 13th Aug 2012 5:16pm
madcima
Italy 2006 Range Rover HSE Td6 Zambezi Silver
hi is the code 11127799225 for the motor for the engine m57n TD6 208 horses, I yesterday mounted in place of the filter in the original
Post #135759 13th Aug 2012 7:28pm
ahebron
New Zealand
I fitted mine today.
It took a bit longer than I expected to arrive due to someone at GSF putting Australia on the label instead of New Zealand.
The complete unit is Vaico part number V20-0956 which equals BMW 11 12 799 224.
I pushed out the the mounting screws and ferrules from the original one and pressed them into the new one as the new screws are a different Allen key size and are not captive.
When I changed the OE foam filter I obviously didnt swap gaskets or fitted the front one the wrong way as the tag was not in its slot. I also notice oil around the injectors so maybe this gasket not fitting right is the cause of oil dripping onto the steering rack. It is never enough to hit the ground and does not appear to be coming from the turbo or wastegate.
Fingers crossed
Post #136380 17th Aug 2012 7:06am
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Mine arrived yesterday from GSF. Will wait till its not freeze in the shed to fit.
Same as Adrian's So I might have to alter a few things. Haven't looked as yet
Gary
Post #136528 17th Aug 2012 3:42pm
ahebron
New Zealand
Ah ha that might explain why mine went to Australia then. If we placed our orders at a similar time someone might have got confused.
And Gary it was a lovely warm late winters day yesterday when I fitted mine in the driveway. Wink
Post #136605 17th Aug 2012 11:08pm
33CHINACARS
We all know that NZ is a state of Australia Very Happy Whistle Very Happy
Gary Rolling with laughter
Post #136677 18th Aug 2012 3:33pm
33CHINACARS
Fitted mine today. 11127799224. Old and new housings look the same. Changed furls & screws as Adrian did. Only difference was the allen key size. Could have left as was.
Could have saved some money and just got this. 11127799367
http://www.ebay.com.au/itm/BMW-1-3-5-SERIE...27c72f7196
Gary
Post #137202 22nd Aug 2012 2:43pm
