Home > Technical (L322) > HELP URGENT
Page 4 of 4 <1234
Nah from my older brother when he stabbed me with one when i was 10 , so it always reminded me what they where called …. Whistle ====================================
Post #136472 17th Aug 2012 10:01am
trainmanone
England 2002 Range Rover HSE Td6 Oslo Blue
well would you belive it ,went for a drive today and all ok apart from the audio no sound the sat nav is ok with sound ,the radio display is as it should be but no statin name or any thing writern in the boxes cant acsess the tape or cd changer computer is ok as well ,any ideas guys had the car about 7 weeks now getting realy Censored off with it ,but love the car as well
regards
pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136573 17th Aug 2012 6:18pm
try another battery disconnection maybe? ... - .- -.
Post #136575 17th Aug 2012 6:32pm
trainmanone
yes tried that twice now stan, with no luck
regards pete
got pic of screen but dont know how to post have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136576 17th Aug 2012 6:35pm
post pics like this,
click on gallery underneath the fullfatrr.com logo,
on the black banner click on upload photos
click on browse and select your pic from your pc/laptop
click continue 4 times
click on your pic and it will increase in size and have the file info
click on and copy the bb code full size and paste onto your post ... - .- -.
Post #136577 17th Aug 2012 6:38pm
trainmanone
hope this works
Post #136578 17th Aug 2012 6:52pm
Bob the B
United Kingdom 2004 Range Rover Vogue Td6 Santorini Black
Pete just a thought but have you tried going in to the "secret code" that you can find on Wiki.
Might be something in there that will help Exclamation
Post #136618 18th Aug 2012 12:23am
trainmanone
well it seams to be an itermitant fault as worked fine while out last night but wouldent come on when restarted at first then came on then off then back on .
did range rover put these faults into the car to keep us on our toes???
when the screen goes as pic you carnt get into the secret code
thinking along the lines of fauly connection in boot area
regards
Post #136637 18th Aug 2012 9:22am
Low voltage?
Post #136638 18th Aug 2012 9:25am
trainmanone
not voltage issue as shows 12.7at battery have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136644 18th Aug 2012 11:13am
Time to dive into the left hand boot area and remove a few connectors to clean them up. This could all be un-related to previous problems ( a bit like changing one radiator hose only to find the next one in line starts leaking !).
You will find it easier to access everything if you remove the black plastic tray as well
Does sound like battery problems though. How old is the battery? Are connections OK?
Also, if you start up and it works, switch off and wait a few minutes for the power to turn off at the SatNav, then try again. (You can watch the SatNav box in the boot and wait for the red light to go out - you should always do this if planning to disconnect the battery otherwise you can foobar your satnav)
Batteries are our favourite source of problems Rolling Eyes
You may need diagnostics to check for / clear any faults ??? .
Post #136650 18th Aug 2012 11:58am
stan wrote:
if the key dont click, you wont be able to turn it ...hows the fullfats battery , if its over about 3 years old it might need replacing..
defo battery... ... - .- -.
Post #136669 18th Aug 2012 1:54pm
trainmanone
is there a phantom model or th range rover????
the reason i ask is that every thing is now as it should be Thumbs Up Thumbs Up Thumbs Up
for the moment any way Whistle Whistle
and havent touched a thing since last post .
once again thanks to every one for all the advice Bow down
its a big learnig curve from an omega
regards pete have hawkeye diagnostics for l322 td6 in the manchester area ,pm for deatalis.
Post #136754 19th Aug 2012 10:31am
Page 4 of 4 <1234
