Home > Maintenance & Mods (L322) > Splitting headlights
ikilla2
2003 Range Rover HSE Td6 Stornoway Grey
I want to paint the inside of the headlights black on my 03 L322, is it possible slit the headlight and get access to the inside? Searches have revealed nothing but I'm sure I have seen pictures of it done? Has anyone got a step by step or a link?
Also, is it possible to split the rear light units?
Thanks guys.
Post #135004 8th Aug 2012 7:57pm
verydisco
THREE WORDS
Cam-Craig-Tech !
Edit : oh, you have 03, simple as 1, 2, 3 : unclip the glass part, pull away, this is dead easy.
Voilà :
Beware though, result are not terrific on this generation of lights.
Rear ones : you must Dremel them out as they are hard glued. l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #135019 8th Aug 2012 8:59pm
what he said ^^^^^^
very easy to do.. ... - .- -.
Post #135020 8th Aug 2012 9:02pm
ikilla2
Thanks fellas.
Post #135024 8th Aug 2012 9:12pm
ikilla2
so, if I go ahead and dremel the rear units open, suggestions for re-sealing them??
Post #137357 23rd Aug 2012 10:04am
Simes
United Kingdom 2011 Range Rover Autobiography Black TDV8 Barolo Black
Does your Dremel have a reverse gear?
Post #137358 23rd Aug 2012 10:08am
some kind of silicon sealant ? ... - .- -.
Post #137359 23rd Aug 2012 10:16am
Araldite
Post #137361 23rd Aug 2012 10:25am
Emperor Mong
United Kingdom 2019 Range Rover Autobiography 2.0 PHEV Loire Blue
Is there a procedure for MY10? I quite fancy MY12 lights.
Post #137453 23rd Aug 2012 6:08pm
verydisco
Get in touch with the man, Craig, but if you wish to do it yourself, double check you have a pair made out of steel (i am not talking about the pair of headlights...) l=Oo\________/oO=l l:OolΞΞΞΞΞΞΞloO:l
Current
Previous:
Post #137459 23rd Aug 2012 6:17pm
