Home > Technical (L322) > TD6 Service / now wont start |
33CHINACARS Member Since: 14 Apr 2011 Location: Tyrendarra, Victoria, Australia Posts: 381 |
Did a service on my TD6. Oil, Fuel, Air, filters & pollen filter. Flattened battery trying to start it. Recharged battery. Every thing worked O'k before service ???
29th Jul 2012 6:00am |
Thanks Meerbusch. But have flattened battery twice now. Doesn't seem to want to prime properly for some reason. Will have another go tomorrow.
29th Jul 2012 6:54am |
PaulB Member Since: 17 Jul 2011 Location: Hampton Posts: 877 |
Maybe there is a blockage in the new filter? Try putting the old filter back on. |
29th Jul 2012 8:12am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16281 |
Always fill the replacement filter with clean diesel before fitting and attempting to start! Otherwise you put a huge strain on not only your battery but your starter motor and the rest of the electrical systems...
29th Jul 2012 10:46am |
Thanks Craig .
29th Jul 2012 11:18am |
I've never had to do that with a diesel before Craig, and with the FF both times its been fine.
29th Jul 2012 12:26pm |
Have blown through filter both ways. So I dont think there is a blockage.
29th Jul 2012 2:33pm |
Fill the filter to the brim with fresh diesel before trying to start |
29th Jul 2012 2:41pm |
arron Member Since: 21 Sep 2010 Location: lincolnshire Posts: 123 |
if you can take the feed to the filter off and no diesel comes out when you turn the ignition on then it wont make a difference if he fills the filter or not, the system needs to register low pressure at the filter head to start. just because the low pressure pumps are running doesnt mean they are pumping, start by removing the feed to the low pressure pump infront of the rear wheel and turning the ignition on to see if diesel flows. if it does the problem is with the secondary pump, if it doesnt the problem is the intank pump. time to get dirty, |
29th Jul 2012 10:12pm |
All go now. Reverse filled inline pump. Refilled fuel filter & IP. Cycled ignition a few times, pump sounded different as if it was working this time . Fired into life first go. .
30th Jul 2012 6:43am |
