Home > Technical (L322) > front fan relay
kb5
United Kingdom 2004 Range Rover Vogue 4.4 V8 Giverny Green
front fan relay
Morning all,,
Could some one advise me as to where I would find the relays that control the front electric fan on my l322 v8 petrol, as I need to check if these are working before I shell out for a new front fan assembly.
many thanks \\ Whistle
Post #13262 16th Feb 2010 9:44am
dan_uk_1984
The heater blower fan or the engine cooling fan?
Dan
Post #13267 16th Feb 2010 12:23pm
kb5
Dan
thanks for reply
The fan that's in front of the radiator // I am assuming this is the engine cooling fan
Post #13281 16th Feb 2010 4:49pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
From what I read in RAVE the auxiliary fan is directly controlled by the ECU:
Engine Cooling Fan Control
The engine's electric cooling fan is controlled by the ECM. When the compressor is engaged the ATC ECU sends a fan speed message between 0 (off) and 15 (maximum speed) to the ECM, via the K bus, instrument pack and CAN bus. The ATC ECU requests the cooling fan on when:
The vehicle speed is less than 44 mph (70 km/h)
There is no fault with the compressor clutch circuit
Battery voltage is less than 16 V.
The fan speed requested depends on the pressure in the refrigerant system. The higher the pressure the faster the fan speed that is requested. When vehicle speed increases to more than 50 mph (80 km/h) the ATC ECU changes the fan speed request to 0 until vehicle speed decreases to less than 44 mph (70 km/h) again.
Post #13335 18th Feb 2010 7:35am
dan_uk_1984
I imagine it will be a stepper resistor, similar to the blower final stage resistor. In which case it will usually fail at 1 or 2 speeds but will still work at others.
The fan doesn't actually do much other than cool the A/C condenser, and even then only at low speeds. What is the actual problem you're having?
Regards,
Dan
Post #13342 18th Feb 2010 10:58am
adara
Actually did anyone see their auxiliary fan spinning? I never saw mine turn, even while using the A/C on a hot day... How can one check it?
Post #13343 18th Feb 2010 11:51am
dan_uk_1984
Just depends on refrigerant pressure (I imagine TestBook can test it though?). Under normal driving the fan shouldn't need to come on, but maybe on a 30 degree day in full sun with the A/C on max I've heard it flick on whilst in stationery traffic.
Don't forget the system is multi-climate. So it should worth fine in Sahara or South Kensington, so a lot of the time the aux fan is not required.
Dan
Post #13344 18th Feb 2010 12:00pm
adara
On most (all) of the cars I owned the electric fan started turning when A/C was enabled while stationnary. Not on the RR.
There is a very intriguing info in RAVE:
"To protect the system from extremes of pressure, the ATC ECU disengages the compressor clutch if the pressure:
Decreases to 1.9 ± 0.2 bar ( 27.5 ± 3 lbf/in 2 ): the ATC ECU engages the compressor clutch again when pressure increases to 2.8 ± 0.2 bar (40.5 ± 3 lbf/in 2 )
Increases to 33 ± 1 bar (479 ± 14.5 lbf/in 2 ): the ATC ECU engages the compressor clutch again when pressure decreases to 23.5 ± 1 bar (341 ± 14.5 lbf/in 2 )"
33bar!!! That's a lot of pressure!
Post #13346 18th Feb 2010 12:08pm
dan_uk_1984
You also have the viscous fan constantly pulling air in though, so this is generally why other (lesser) cars have to have the condenser fans running all the time. On smaller cars this puts a significant load on the alternator, coupled with the compressor that’s why it’s more economical to leave the a/c off. On the RR however most of the time you’re only running the comp’ which on an engine of this size is next to nothing. That and the fact that the A/C should be left on all year round to dehumidify the interior to prevent electrical gremlins.
The pressure quoted above equates to how cold the evaporator is, so when its high pressure there is no need for the comp’ to be running or too much ice may form (also if ice does form the pressure will increase, it cuts out and then it defrosts) That’s why it cycles on and off.
Dan
Post #13348 18th Feb 2010 12:21pm
kb5
Regards,
Dan
Dan,
Autologic fault found p0691 which is fan 1 control circuit low, I have spoken to a LR tech who advised me that to remedy this I would need a complete new front fan assembly the cost of which is around 500 pounds ouch! I did do a seperate post to this prob before, however I never got any responce.
The main problem is where I am at the moment it gets over 40c in the summer so I need as much cooling the engine as possible.
Post #14037 28th Feb 2010 12:10am
adara
I never saw my electrical fan spinning and after a frontal collision I had a new bumper and fan installed and I can tell you the new one isn't spinning either. The new fan is definitely OK and the dealer swears the diagnose shows no errors but I'm convinced something is wrong. As the fan is controlled directly by the ECU (no relay), there is really no other element to be blamed, except for the pressure sensor on the A/C maybe, but as the compressor clutch is disengaging I suppose that one works. It's cold now here, but already the A/C pipe is hot and the fan is not spinning.
Post #14043 28th Feb 2010 8:46am
StevieH
I was just checking all my fluid levels when i notice several disconnected wires on the front offside of the radiator. I plugged them all back together and found that they ended up on a small black plastic box attached to the radiator ousing and the plastic clip was broken attaching it to the housing. Guessing this is the wiring for the electric fan and no idea how long it has been disconnected. Never had an overheating problem yet but I have had to put in about 5 litres of coolant since my alternator got replaced in December. Here's hoping it was only an air lock (fingers nervously crossed).
Post #14067 28th Feb 2010 10:59pm
adara
That's just the pollution sensor. It doesn't control the fan.
Post #14082 1st Mar 2010 9:05am
