![]() | Home > Technical (L322) > front fan relay |
The heater blower fan or the engine cooling fan?
kb5 Member Since: 20 Jan 2010 Location: currently in The Sudan, dont ask Posts: 63 ![]() ![]() ![]() |
thanks for reply The fan that's in front of the radiator // I am assuming this is the engine cooling fan |
adara Member Since: 09 Dec 2008 Location: Eastern Europe Posts: 819 ![]() ![]() ![]() |
From what I read in RAVE the auxiliary fan is directly controlled by the ECU:
I imagine it will be a stepper resistor, similar to the blower final stage resistor. In which case it will usually fail at 1 or 2 speeds but will still work at others. The fan doesn't actually do much other than cool the A/C condenser, and even then only at low speeds. What is the actual problem you're having? Regards, Dan ![]() |
Actually did anyone see their auxiliary fan spinning? I never saw mine turn, even while using the A/C on a hot day... How can one check it? |
Just depends on refrigerant pressure (I imagine TestBook can test it though?). Under normal driving the fan shouldn't need to come on, but maybe on a 30 degree day in full sun with the A/C on max I've heard it flick on whilst in stationery traffic.
On most (all) of the cars I owned the electric fan started turning when A/C was enabled while stationnary. Not on the RR.
You also have the viscous fan constantly pulling air in though, so this is generally why other (lesser) cars have to have the condenser fans running all the time. On smaller cars this puts a significant load on the alternator, coupled with the compressor that’s why it’s more economical to leave the a/c off. On the RR however most of the time you’re only running the comp’ which on an engine of this size is next to nothing. That and the fact that the A/C should be left on all year round to dehumidify the interior to prevent electrical gremlins. The pressure quoted above equates to how cold the evaporator is, so when its high pressure there is no need for the comp’ to be running or too much ice may form (also if ice does form the pressure will increase, it cuts out and then it defrosts) That’s why it cycles on and off. Dan ![]() |
Dan, Autologic fault found p0691 which is fan 1 control circuit low, I have spoken to a LR tech who advised me that to remedy this I would need a complete new front fan assembly the cost of which is around 500 pounds ouch! I did do a seperate post to this prob before, however I never got any responce. The main problem is where I am at the moment it gets over 40c in the summer so I need as much cooling the engine as possible. |
I never saw my electrical fan spinning and after a frontal collision I had a new bumper and fan installed and I can tell you the new one isn't spinning either. The new fan is definitely OK and the dealer swears the diagnose shows no errors but I'm convinced something is wrong. As the fan is controlled directly by the ECU (no relay), there is really no other element to be blamed, except for the pressure sensor on the A/C maybe, but as the compressor clutch is disengaging I suppose that one works. It's cold now here, but already the A/C pipe is hot and the fan is not spinning. |
StevieH Member Since: 05 Feb 2009 Location: Cumbernauld, Lanarkshire Posts: 117 ![]() ![]() ![]() |
I was just checking all my fluid levels when i notice several disconnected wires on the front offside of the radiator. I plugged them all back together and found that they ended up on a small black plastic box attached to the radiator ousing and the plastic clip was broken attaching it to the housing. Guessing this is the wiring for the electric fan and no idea how long it has been disconnected. Never had an overheating problem yet but I have had to put in about 5 litres of coolant since my alternator got replaced in December. Here's hoping it was only an air lock (fingers nervously crossed). |
That's just the pollution sensor. It doesn't control the fan. |
