Home > General > Should I update. should I not, if I do 3.6 or 4.4 ? |
Ukdave104 Member Since: 26 Apr 2012 Location: Aberdeen Posts: 116 |
I faced the same decision when I upgraded from the D4. I was told that the 4.4 was much nicer than the 3.6 so thats what I went for.
27th Jul 2012 4:23pm |
Rolo Member Since: 11 May 2011 Location: UK Posts: 852 |
Can that be a 4.4TDV8 on a 59 plate ? I thought the diesel 4.4 only came in late 2010 ??
27th Jul 2012 4:29pm |
Autobiography Member Since: 10 May 2011 Location: UK Posts: 922 |
No way is 59 a 4.4. I think some may have crept in as a late 10 reg. It didn't really enter production until late August/September 2010, so 60 reg is your bet. |
27th Jul 2012 5:15pm |
Java Jungle Member Since: 22 Mar 2010 Location: Monte-Carlo Posts: 420 |
Is there really that much of a difference between the 3.6 and the 4.4? Was thinking of getting a 4.4 in case the new L405 was going to look as it seems it will after seeing all the pictures...
27th Jul 2012 7:51pm |
It's the combination of the bit of extra power & the 8 speed gear box that makes the 4.4 amazing |
28th Jul 2012 8:03am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16263 |
There is a fourth option... Upgrade/convert yours and use the rest of the money elsewhere? Seriously for under £4k you could have it looking the same as a 12MY and for under £10k it could look the same as the 59reg Overfinch you mentioned... Leaving you £30k+ to do with as you wish... Food for thought..... http://cam-tech-landrover.co.uk/conversion-packages/ Craig |
28th Jul 2012 8:35am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35248 |
good point craig , and you wont loose so much in depreciation..... ... - .- -.
28th Jul 2012 8:55am |
does that conversion include a 4.4 engine & 8 speed box craig |
28th Jul 2012 2:49pm |
I think the conversion would work up to a point. How good is the TD6 still ?? If it is in very good nick, then the conversion seems to be the way to go, bearing in mind you won't use it hell of a lot.
28th Jul 2012 7:20pm |
We can do anything if you have the funds sir
28th Jul 2012 8:11pm |
Craig |
28th Jul 2012 8:12pm |
bjs Member Since: 27 May 2010 Location: Surrey Posts: 54 |
Thanks guys,
30th Jul 2012 7:35am |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 |
Does the Overfinch add that much to the value? I bought my 2008 TDV8 for £25k with similar mileage, and judging by the other thread on TDV8 values, its already depreciating!! Sounds an awfully high price but then I still don't know much about these things! Lloyd Barnes Current Crendon 427 Sideoiler Cobra in build... 7 litres of madness! Gone 2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer 2008 VW Touareg 3.0Tdi 6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph |
30th Jul 2012 9:10am |
