Home > Technical (L322) > TDV8 Engine System Fault + Limp at altitude
Martin
Site Admin
Hi all,
Dad's 08 TDV8 has got a bit of a strange issue.
Under light pedal application - pulling out of junctions, etc - it will intermittently flag up "Engine System Fault" on the dash, special programs unavailable etc and go into limp home mode. Key off and restart and it is either OK, or it does it again. Putting it into a TR mode other than Normal seems to stop it doing it.
Now, the odd thing is - it has only done it when above about 1300m altitude, below that is absolutely will not repeat it.
Anyone had similar?
Post #133083 26th Jul 2012 2:25pm
found this which refers to a TSB ecm re-flash that's necessary..
http://www.rangerovers.net/forum/9-range-r...e-tsb.html ... - .- -.
Post #133085 26th Jul 2012 2:36pm
Martin
Site Admin
That appears to be NAS and 4.4 AJV8 only...
Post #133086 26th Jul 2012 2:36pm
Embarassed ... - .- -.
Post #133087 26th Jul 2012 2:37pm
ebajema
Sounds like an issue with the MAP sensor not working over the full range or waste gate of the turbo acting up (reducing turbo pressure). MY 2010 5.0 SC Galway green and sand interior!!
Post #133088 26th Jul 2012 2:38pm
Martin
Site Admin
Just following this up to help others, this turned out, thankfully, to be the two top intercooler pipes and not turbo related Very Happy
Post #207138 1st Sep 2013 10:37am
