Home > Technical (L322) > Servotronic Valve / Hydraulic Transducer
Page 3 of 4 <1234>
Aurrian
2005 Range Rover Vogue SE Td6 Java Black
47p2 wrote:
So do you have the two new ones kicking around or even the old ones lying abandoned somewhere?
I have one if you want it - the other one is obviously in pieces.
Post #130968 13th Jul 2012 7:02pm
Hi Aurrian, That would be appreciated I will send you a pm
Post #130979 13th Jul 2012 8:12pm
Met Aurrian this morning and he kindly gave me a bolt for my valve, so will fit that today.
Thank you very kindly sir Thumbs Up
Bolt now changed which will allow me to remove the valve at a later date if required
Post #131048 14th Jul 2012 11:37am
nubbin
United Kingdom 2019 Range Rover Vogue SE SDV8 Corris Grey
Well, there's good news and bad news - the Winter wheels and tyres have completely eliminated the shakes! WooHoo!!!!
The bad news is that I obviously need to buy some new 20" wheels - shame! Cool
Ebay here I come! Mr. Green
Post #131092 14th Jul 2012 7:04pm
Can someone let me know approximately how much fluid is lost when changing the servotronic valve?
Post #133564 30th Jul 2012 1:10pm
if you leave the little filter in then only a couple of teaspoons, take the filter out and you need to be quick in inserting the new filter cos it does spill out quite a bit............ ... - .- -.
Post #133567 30th Jul 2012 1:14pm
Thanks Stan Thumbs Up
Post #133569 30th Jul 2012 1:18pm
Job done 23 minutes and only lost about a tablespoon of fluid, handy having a ramp. Mr. Green
The old filter fell out when I removed the valve Shocked
Post #133577 30th Jul 2012 1:51pm
nice one john... Thumbs Up ... - .- -.
Post #133579 30th Jul 2012 1:57pm
Was out in the FFRR today and can't believe the difference the new servotronic valve makes. Steering is nice and light now, most noticeable on roundabouts Thumbs Up
Post #133747 31st Jul 2012 12:30pm
Pedrochellie
United Kingdom 2003 Range Rover Vogue 4.4 V8 Epsom Green
Can anyone tell me how much the servotronic valve costs?
Cheers Thumbs Up FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #141444 16th Sep 2012 9:36pm
about £60'ish.. ... - .- -.
Post #141454 17th Sep 2012 6:37am
Pedrochellie
Cool thanks Stan Thumbs Up FFRR Vogue 2003 4.4V8 - Epsom Green & Ivory
Ducati 999S
Post #141462 17th Sep 2012 7:47am
See below picture of a new Servotronic Valve, screws & filter from Dan @ Duckworths.
Worth noting instructions say:
The screws must be tightened in the following order:
1. (bottom) 0.5nm
2. (top) 1.5nm
3. (bottom) 2.9nm
4. (top) 2.9nm
Failure to do this can cause malfunction....
Post #260187 19th May 2014 7:34am
i see you've just realised that thats the filter next to the bolts.. Wink ... - .- -.
Post #260191 19th May 2014 7:40am
Page 3 of 4 <1234>
