![]() | Home > Maintenance & Mods (L322) > GSM Controller for FBH - Installation Completed |
awclymm Member Since: 09 Jun 2012 Location: Cheshire, UK Posts: 135 ![]() ![]() ![]() |
Hi
tomthevet Member Since: 14 Jan 2012 Location: Scotland Posts: 283 ![]() ![]() ![]() |
Does the dial up warm up work on Jacqui too??
gabbo Member Since: 06 Jul 2012 Location: Nottinghamshire Posts: 56 ![]() ![]() ![]() |
I'm confused....not for the first time. How does the auxiliary heating work normally? 07MY SC VSE (on its way)
There are tons of threads on here about the FBH - just use the search facility and do the reading. Essentially, the FBH works either via a timer or by remote control. The remote control has a finite range, so the ability to activate the FBH by telephone from anywhere has a big benefit. |
Flashman Member Since: 05 Jun 2011 Location: Windsor & Brentwood Posts: 1228 ![]() ![]() ![]() |
What a great upgrade, nice write up. Thanks! Tom
Very nice job!
Thanks Steve - wish I'd known that beforehand!! The trickiest bit of the whole job was the soldering up of the T91 remote. i should have realised that there was a way of bridging the signal between the Webasto receiver and the FBH. Your input will certainly make life a lot easier for others going down this route. When I've got a few minutes I will re-wire my set up as you have suggested, and then I don't have to worry about the battery in the remote letting me down. Cheers, Andy |
Welll it's not something that you can know easily - most things in our cars happen because data is sent over a bus. An old fashioned + or - signal... |
In which scenario? If I keep the set up I currently have with the T91 firing the Webasto, I will still get the 30 mins timing. Are you saying that I wouldn't get the 30 mins timing if I hard wired the Quantek to the Webasto as you suggested? Thx, Andy |
I'm not 100% sure, but I believe the FBH will run as long as it gets a 12v signal on the gn/wt wire. There is a cut-of after 1/2 hr and a low voltage cut-off. I believe the 1/2 hr is controlled by the remote receiver and the low-voltage is in the FBH ECU, but I have never verified this.
Think I'll leave things as they are then.....!! |
Is it possible to do the following to make mainting the setup that much easier?
1. - No idea if this is possible or not. But why would you bother? The quantek comes with a perfectly usable aerial, or if you want something a bit neater you can spend £6 or so and get the stubby aerial.
I have a spare Quantek 500 unit that I bought for a mate to do the same modification, but he has decided to swap his RR for a BMW (don't ask...!) - I've put the Quantek unit up for sale in the for sale / wanted thread. |
