Home > Maintenance & Mods (L322) > TD6 Oil Service & Filter Change - How To
As I'm going to be doing this myself over the next week or so, I thought it might be useful to show and illustrate how to do it following my experiences.
To start off here's a picture of the kit you'll need to perform a service of this type;
9 litres of 5w40 Castrol Diesel Edge oil (Approx £100)
TD6 service kit - Oil filter, air filter, charcoal filter, fuel filter, sump washer (Approx £40)
As I do the work I'll detail how I did it and the issues I faced, along with more pictures. Discovery 4 HSE
Post #5343 1st May 2009 5:59pm
Right, the work is done and here is an abridged version of how to do this for yourself: I'd recommend getting the L322 Workshop Manual to refer to, although I found it lacking in some details.
1. Put the car into Off Road height so you can crawl underneath. Ideally you should use proper axle stands, I didn't have any that were up to the job.
2. Ideally you should disconnect the battery negative terminal, however as I needed to use the air suspension I left mine connected
3. Using a 10mm socket set undo the 6 bolts holding in the engine undertray
3. Using another socket, undo the sump plug seen here, it's on the rear left side of the engine (driver's side) I used 2 old washing up bowls to collect the oil
4. Remove the engine plastic covers, the one at the front and the left side which houses the air filter. You need an allen head set for this.
5. Remove the fuel filter by unclipping the electric feed, remove the sensor on the top using a star shaped bit, unfasten the two fuel hoses (these are jubilee clips with a weird fitment - you can undo them with a flat screwdriver but will need a pair of pliers to put them back. I'd recommend having 2 normal jubilee clips to replace them in advance) and then the star shaped torx bit holding the body at the back of the filter. Remove from engine bay upright as it contains 1/2 litre of fuel. I discarded it as it looked like it had all sorts of rubbish in it.
6. With the fuel filter out of the engine bay this gives you more room to access the oil filter. If you have a 35mm socket use this, I didn't so I used a set of large mole grips. Place a rag over the alternator underneath the oil filter housing in case of any drips. Unscrew the oil filter head slowly, then once undone remove centre spindle. paper filter is inside, remove this. Clean the filter head and body to remove old oil. Replace new filter into the body and put new rubber gasket onto the thread, lube with fresh oil. replace head onto the body.
7. Fit new fuel filter in reverse procedure of removal. Ensure fuel hoses are tight and leak free.
8. Remove old air filter and hoover out any debris left in the housing as seen below. Mine was full of all sorts of rubbish because the last service was done poorly and the casing was not put back properly, letting in debris and of course air leaks.
Old filter REALLY needed swapping
9. Undo the 3 bolts holding the pollen filter housing together. These are 8mm. They are situated underneath the foam padding above the engine block at the rear of the engine bay. Lift off the rubber sealing trim across the back of the bonnet and open up the pollen filter housing. Pull out the old, slide in a new one. Replace trim and 3 bolts. This is the easiest part of the service.
10. Replace sump plug washer with a new one and fit back into sump. Fill up engine with 9 litres of fresh oil.
11. Replace plastic engine covers ensuring the air filter is properly sealed. This can be a bit tricky, when you have put the new air filter in you really have to squeeze it in backwards so that the rear part drops into the spigot mounting, only if this is done will the cover go back on ok.
12. Start engine and check for leaks from sump, oil and fuel filters.
13. Refit the engine undertray with the 6 bolts.
This is how the engine bay SHOULD look after a service, certainly not the way the garage left it for me last time.
Please dispose of used engine oil and any other chemicals such as drained fuel in an environmentally friendly manner such as your local domestic refuse tip where proper oil containers are held.
I bought a pattern part service kits from Britpart as these are a reputable supplier of LR parts. I used the best oil as I didn't think it was worth any risk. Should the engine blow up for ANY reason, I wouldn't want to be told that it was due to using cheap oil and because I wanted to save £20. In any case, Halfords own oil was only marginally cheaper so I didn't see the point in NOT buying Castrol.
At the end of the day I have peace of mind knowing my car has been serviced with meticulous detail, unlike the previous so called 'proper' service. They had not put the air filter housing back, hence it was full of leaves and black as soot. The fuel filter too did NOT look like it had EVER been replaced, can this amount of rust form in 6000 miles? From memory this has always been like this, so looks like no one ever changed it, not even the Dealers.
If anyone wants to ask me any questions on the procedure feel free to PM me. Discovery 4 HSE
Post #5373 3rd May 2009 9:27pm
ELLIOTTNESS
2006 Range Rover Vogue SE Td6 Java Black
Hi I have a problem with my range rover td6. When I accelerate for a short time the car cuts out & the clear fuel pipe under the bonett is full of air. If I turn the ignition on to prime the system back, it will then start. Also if I let the fuel tank run to quarter of a tank you can see air in the clear fuel line. I have changed the fuel filter & this problem still persists. This is a recent problem as the car has been fine up unitl recently. It seems there is air being dragged into the system or a blockage. Is there another filter within the system or have you come across this type of problem before?
Any advice or help you can give would be appreciated.
Many thanks
Dave Elliott
07879 404950
Post #42436 15th Dec 2010 10:22pm
Andy
I did mine at the weekend. I didn't have that plastic undertray cover on mine though?
Something else I need to purchase I think! 2010 MY Vogue SE TDV8 3.6 Stornoway Grey- fully loaded
Post #62391 2nd May 2011 3:02pm
Charcoal filter? Oh, that's the pollen filter, init Embarassed .
Post #73740 25th Jul 2011 11:33pm
Just finished doing mine.
Notes:
1. Don't be too alarmed when the car won't start. just takes a little while for the fuel to make it through the filter.
2. When putting the left hand engine cover back on, best to locate loosely the bolt at the back at the bottom first
3. My arms aren't long enough to reach a dropped allen key in the undertray from the inside Smile .
Post #74925 5th Aug 2011 4:10pm
Richcl
United Kingdom 2002 Range Rover HSE Td6 Zermatt Silver
I've dropped various tools in the engine bay that have ended up on the undertray.
I use a magnet to drap item to hole or vernt in tray to retrieve (If they are metallic of course)
Post #74935 5th Aug 2011 5:34pm
Most of the pics aren't working for me Sad
I got the full Brit part kit and knockeD the air and cabin filters out last night, took longer cleaning them out an refitting the airbox cover properly... FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #130808 13th Jul 2012 7:01am
Andy3681
United Kingdom 2005 Range Rover Vogue Td6 Cairns Blue
Air box cover can be a pig, as Joe says try to get the rear left hand ( Lowest) in first Mine was a blue one! Smile
Post #130812 13th Jul 2012 8:37am
this 'how to' is from 2009 so the pics have gone into cyber space somewhere.. Neutral ... - .- -.
Post #130820 13th Jul 2012 9:30am
Easiest way to access the air box bolts is to remove the unit that holds the cabin filter, it is held on by 2x13mm nuts and a 30 second job Thumbs Up
Post #130829 13th Jul 2012 10:18am
The URLs seem to have changed so have updated them. Discovery 4 HSE
Post #131390 16th Jul 2012 2:58pm
cheers fella Smile will be doing it in the next few nights:) FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #131443 16th Jul 2012 5:51pm
33CHINACARS
Australia 2017 Range Rover Autobiography SDV8 Santorini Black
Thanks for the excellent how to. Have to do mine soon too Thumbs Up Thumbs Up
Gary
Post #131732 18th Jul 2012 9:20am
Done it again for the second time now in my ownership and thanks again for the write up, it's always good to have it on hand Smile
I do seem to let the oil drain plug and the socket attached to it end up in my black bucket though!!!
The engine is always warm when I do it and this te plug is too hot to touch Sad
Think I'll get it down to an hour all in this year as it took 90mins all in this time Smile FFRR MY06 facelift With TDV8 Alloys Zeros/ATR's
Post #131733 18th Jul 2012 9:25am
