Home > Technical (L322) > My First Defeat - Airbag Won't Come Off |
steviebabes Member Since: 28 May 2012 Location: Eastbourne Posts: 67 |
I bought my L322 in February this year. I am wholly untechnical, being a desk type. Despite this, I have successfully replaced fogged-up rear lights with supercharged ones, swapped the gearknob for a walnut autobiography model, and replaced a smashed nearside front lamp housing.
10th Jul 2012 10:15am |
Martin Site Admin Member Since: 24 Mar 2007 Location: Hook Norton Posts: 1665 |
How are you trying to remove it? |
10th Jul 2012 10:25am |
You have to get whatever you are using as a tool in the 'channel' once it is in the outer hole which means pulling lightly. Also, with the wheel centered, the 'channels' are parallel to the ground (pic 1).
10th Jul 2012 10:52am |
I'm using a flat-ended cylindrical stick (part of a magician's stage equipment - but not his wand!) just a fraction smaller than the hole itself. Perhaps I need something just a bit smaller in diameter. I'll see if Halfords have a T-25 and try again.
10th Jul 2012 11:43am |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
I had exactly the same problem as you when I replaced my steering wheel earlier this year.
10th Jul 2012 12:19pm |
An allen key is great too.
Indeed, and it's advice I often give. sorry RRC 2Dr, RRC 4Dr, P38, and 2 L322s (wife thinks I'm nuts - prob right, too) |
10th Jul 2012 1:08pm |
Tonight I used a UNIOR brand 3mm flat-ended hex tool which I bought for £5 inc postage. Importantly, the shaft itself is 3mm dia so fits easily into the small hole. The airbag springs were released fairly easily on both sides, the right-hand side being, again, the more resistant. The airbag is now sitting on the passenger seat and tomorrow I will fit my lovely new walnut & nappa wheel after giving the area a good clean.
13th Jul 2012 9:54pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
Always remember to put a little downward pressure as if pushing the airbag back on, this helps the last retaining clip let go!!
13th Jul 2012 11:38pm |
