Home > Technical (L322) > My First Defeat - Airbag Won't Come Off
steviebabes
England 2003 Range Rover HSE 4.4 V8 Epsom Green
I bought my L322 in February this year. I am wholly untechnical, being a desk type. Despite this, I have successfully replaced fogged-up rear lights with supercharged ones, swapped the gearknob for a walnut autobiography model, and replaced a smashed nearside front lamp housing.
Yesterday, planning to replace my worn steering wheel, I disconnected the battery and replaced my cabin air / pollen filter in the five minutes waiting time for any capacitors etc to discharge.
And then the defeat - the left airbag spring popped-off fairly easily, but the right side one - well, I couldn't even positively find the beggar, let alone release it.
So my new walnut wheel sits in its box while I figure out what to do next.
I might have to cheer myself up with a purchase of some sort . . . 2003 4.4 HSE Epsom Green / Sand. Lovely!
Post #130216 10th Jul 2012 10:15am
Martin
Site Admin
How are you trying to remove it?
Post #130224 10th Jul 2012 10:25am
SteveMFr
Site Sponsor
You have to get whatever you are using as a tool in the 'channel' once it is in the outer hole which means pulling lightly. Also, with the wheel centered, the 'channels' are parallel to the ground (pic 1).
I also would not use a screwdriver as you'll just slip off the clip (round wire). I use the biggest T-handled torx I can make fit (T-25?). It's actually quite easy once you've done it.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #130229 10th Jul 2012 10:52am
steviebabes
I'm using a flat-ended cylindrical stick (part of a magician's stage equipment - but not his wand!) just a fraction smaller than the hole itself. Perhaps I need something just a bit smaller in diameter. I'll see if Halfords have a T-25 and try again.
Thank you for such great photos! 2003 4.4 HSE Epsom Green / Sand. Lovely!
Post #130240 10th Jul 2012 11:43am
I had exactly the same problem as you when I replaced my steering wheel earlier this year.
Some kindly soul suggested using an allen key, which worked beautifully.
I concur with SteveM's suggestion of using the largest diameter tool you can find. Si. <This is my name.
Post #130249 10th Jul 2012 12:19pm
SteveMFr
Site Sponsor
An allen key is great too.
Indeed, and it's advice I often give.
sorry
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #130253 10th Jul 2012 1:08pm
benjj
United Kingdom 2004 Range Rover Vogue Td6 Zambezi Silver
Wish I'd known about the allen key trick. I ended up using a narrow wooden paintbrush from my 4 year old daughter's art set. She was not happy when it came back all chewed up.
Post #130260 10th Jul 2012 1:33pm
steviebabes
Tonight I used a UNIOR brand 3mm flat-ended hex tool which I bought for £5 inc postage. Importantly, the shaft itself is 3mm dia so fits easily into the small hole. The airbag springs were released fairly easily on both sides, the right-hand side being, again, the more resistant. The airbag is now sitting on the passenger seat and tomorrow I will fit my lovely new walnut & nappa wheel after giving the area a good clean.
Thank you all for your suggestions and advice. 2003 4.4 HSE Epsom Green / Sand. Lovely!
Post #130986 13th Jul 2012 9:54pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
Always remember to put a little downward pressure as if pushing the airbag back on, this helps the last retaining clip let go!!
3mm tee bar allen key is perfect fit Thumbs Up Thumbs Up Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #131003 13th Jul 2012 11:38pm
