![]() | Home > Technical (L322) > Leaky windscreen |
ahebron Member Since: 01 Jan 2012 Location: The other Eastbourne Posts: 341 ![]() ![]() |
Hmmm. I thought by moving up to a FFRR from a 300TDi Disco I would be getting away from water leaks. Disco leaked through body panel overlaps at rh lower screen.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35648 ![]() ![]() |
seal with black silicon or a new windscreen. ... - .- -.
Thank you very much for your kind offer Windscreen Dave but as I live some 12000 miles away I will unfortunately have to pass on it |
Windscreen Dave Member Since: 28 Jun 2012 Location: Lincoln Posts: 29 ![]() ![]() ![]() |
Sorry saw Eastbourne and not the NZ sticker underneath lol. I wouldn't try taking top trim out as they don't go back in very easily if at all due to being stuck into bond. Best way is as you said to pull headlining back depending on where the hole is you may need to loosen some of the headlining off by removing sun visors and centre roof console.
