Home > Technical (L322) > Protective brake disc cover rotted round bolt holes! |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6407 |
Assorted washers required, works well until the disc guards rot away around them. You may have to remove the discs to get decent access. And yes the only proper solution is to remove hubs to replace them. The other way is to cut through to remove, and then cut new ones and refix (or weld) when in position. .
5th Jul 2012 9:23pm |
Shropshire lass Member Since: 03 Oct 2011 Location: Shropshire Posts: 58 |
Thanks Joe , had a nasty feeling that the proper fix could be a complicated one! My brother in law is very handy but isn't a Landrover guy so just wanted some pure Landrover advice , this site never disappoints me
5th Jul 2012 9:35pm |
Richcl Member Since: 23 Sep 2010 Location: Tewkesbury, Glos Posts: 1011 |
I used "penny" washers to repair mine, simple fix and painted over to stop further rust. |
5th Jul 2012 10:21pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
I had the same problem. Didn't bother with the washers, just used tin snips and cut them off, with a view to replacing. Think they worked out about £60 a corner so decided I didn't need them. They are weather shields to stop mud and stones getting onto the disc/pad. As I don't do any mud stuff didn't see the need, and to do a propper job means splitting the hub which it a total PITA! [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
5th Jul 2012 10:58pm |
Thanks Richci ans Rob .think may go down the removal route . Although I tow a horse box with mine it doesn't involve an awfull lot of offloading . Will look at the washer idea with some protective paint too. My travelling picnic blanket was invaluable for raising the height of my range and lying underneath it! |
6th Jul 2012 7:01am |
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 |
On the front all you need to remove is the caliper , caliper carier and brake disk and they just bolt on onto no6 Range Rover
6th Jul 2012 9:04am |
If fitting new backplates you need to
6th Jul 2012 9:09am |
Thanks to 47p2 & speedymarktd6
6th Jul 2012 3:00pm |
