Td6 - High Pressure Fuel Pump | |
What do we know about the high pressure fuel pump in relation to leaking ?
About a week ago, I took my car to the local specialist to fix a diesel leak.
They said that the high pressure fuel pump on the passenger side of the engine was damp.
They checked the pipes for cracking etc and reattached them to the pump and told me to run it for a week or so to see if the diesel smell stops.
Well I've only done about 15 miles since then, which may not be enough of a run to burn off what diesel is still there, but I can still smell a strong diesel smell under the bonnet. Not as bad as before, but still there.
Probably need to have a good run, but if its the fuel pump, they are pretty expensive I believe.........
Anyone else had similar symptoms ?
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
