Home > Maintenance & Mods (L322) > Td6 - High Pressure Fuel Pump
mjdronfield
What do we know about the high pressure fuel pump in relation to leaking ?
About a week ago, I took my car to the local specialist to fix a diesel leak.
They said that the high pressure fuel pump on the passenger side of the engine was damp.
They checked the pipes for cracking etc and reattached them to the pump and told me to run it for a week or so to see if the diesel smell stops.
Well I've only done about 15 miles since then, which may not be enough of a run to burn off what diesel is still there, but I can still smell a strong diesel smell under the bonnet. Not as bad as before, but still there.
Probably need to have a good run, but if its the fuel pump, they are pretty expensive I believe.........
Anyone else had similar symptoms ?
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #129374 4th Jul 2012 12:45pm
Take out a second mortgage for the pump Shocked
They are usually pretty robust and not a lot of problems with them , most likely cause will have been a leaking joint or pipe. It may take a couple of longer runs to burn the smell off the engine block
Post #129388 4th Jul 2012 1:45pm
mjdronfield
Thanks.
That was what I was hoping, but the smell is pretty strong after I turn the engine off, but then I suppose it will be for a while.
I got 12 months warranty (for what its worth) when I got the car last November.
I trust the part will be covered if needs be, as its not a consumable item..........
Will give it a good run and see if its any better. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #129395 4th Jul 2012 2:19pm
There is plenty access around the pump so might be worth buying a can of Gunk and giving it a wash down, don't be tempted to use a pressure wash in there though. You could also spray it with WD40 and use a paint brush to loosen the crud, then wipe it clean with a rag
Post #129399 4th Jul 2012 2:44pm
