![]() | Home > Technical (L322) > CCF files can these be got from dealer 2006 SC |
wiggs Member Since: 29 May 2010 Location: Manchester Posts: 182 ![]() |
I would suspect its the tv in motion lead at fault ... Why don't you remove it and see if the others start working |
highfellzippy Member Since: 20 Aug 2011 Location: Yorkshire Posts: 153 ![]() ![]() ![]() |
where is the tv in motion lead on the earlier cars it was plugged into tv tuner but cant see it in my car anywhere 2006 touchscreen |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
its behind the screen i think... ... - .- -.
I think you have to get behind the screen as Stan says as I think the lead plugs into the rear then the car lead plugs into the TV in motion lead. |
Jpickie Member Since: 02 Nov 2011 Location: Oxfordshire Posts: 44 ![]() ![]() ![]() |
I have had a similar problem with my DVD player showing a blue screen and saying something like 'incorrect signal'. It turns out that when my kids have been turning off the RSE with the remote control if you hold the on / off button on the left side for too long it puts the DVD player into NTSC mode and then displays the error message. The only way to correct this is to hold the button again on the remote whilst pointing it at one of the rear screens until it returns to the normal PAL mode again. It was my understanding that the TV in motion lead for the touch screen units is located at the integrated head unit which is behind the lower glove box on a facelift and I would assume it's at the same place on pre- facelift with touchscreen. As for the reverse camera have you tried entering the test mode for the touchscreen to see if the camera is showing a picture regardless of weather it's in reverse gear. There is a write up of how to enter the test mode using the 753 hack on the WIKI pages, at least that will narrow down if your getting a picture or not. Regards Jon MY2007 S/C - Stornoway / Jet |
the saga continues 7 days in dealer and counting
hang on a minute, is it not the conversion peeps that caused this problem not the dealer... ... - .- -. Y. O. L. O. . |
Indeed, TV in Motion is not a standard fit either..... I know what my dealer would say |
What ever the problem is the so called dealer should have a answer for me by now i dont think the conversion affected it but its a possibility
JustinP Member Since: 24 Oct 2010 Location: Cambridge Posts: 889 ![]() ![]() ![]() |
Have you or a previous owner fitted TV in-motion, or is the TV working when driving due to corrupt CCF?
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 ![]() ![]() ![]() |
I think you've got that backwards. mate. ![]() Back when I worked in TV, I learned what those acronyms meant: NTSC = Never The Same Color PAL = Pale And Lurid Jim 2000 NAS HSE 2005 NAS HSE |
You forgot the French SECAM = System Essentially Contrary to American Method
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1521 ![]() ![]() |
@Jim & Steve |
It won't be an unplugged MOST fiber - if the loop is not closed MOST won't work. That is why all units on the MOST bus have 2 fiber connectors.
