Home > Technical (L322) > CCF files can these be got from dealer 2006 SC
highfellzippy
United Kingdom 2015 Range Rover Autobiography SDV6 Montalcino Red
as my rear camera and DVD player are not working correctly camera wont turn on & DVD says wrong video (or something like that)
but i have TV in motion when driving
could someone have changed the CCF file settings
and can i get the original files from Land Rover
i have owned the car three weeks and had it avaliable to use 4 days !!!!! Big Cry Big Cry
Post #129020 2nd Jul 2012 7:52pm
wiggs
I would suspect its the tv in motion lead at fault ... Why don't you remove it and see if the others start working Question
Dealers can load your "as built CCF " but tv on the move is not a standard feature Bluetooth Exchange www.bluetoothexchange.co.uk
Post #129062 2nd Jul 2012 10:04pm
highfellzippy
where is the tv in motion lead on the earlier cars it was plugged into tv tuner but cant see it in my car anywhere 2006 touchscreen
Post #129088 3rd Jul 2012 7:31am
its behind the screen i think... ... - .- -.
Post #129107 3rd Jul 2012 8:57am
I think you have to get behind the screen as Stan says as I think the lead plugs into the rear then the car lead plugs into the TV in motion lead.
Post #129108 3rd Jul 2012 9:03am
Jpickie
United Kingdom 2007 Range Rover Vogue SE Supercharged Stornoway Grey
I have had a similar problem with my DVD player showing a blue screen and saying something like 'incorrect signal'. It turns out that when my kids have been turning off the RSE with the remote control if you hold the on / off button on the left side for too long it puts the DVD player into NTSC mode and then displays the error message. The only way to correct this is to hold the button again on the remote whilst pointing it at one of the rear screens until it returns to the normal PAL mode again. It was my understanding that the TV in motion lead for the touch screen units is located at the integrated head unit which is behind the lower glove box on a facelift and I would assume it's at the same place on pre- facelift with touchscreen. As for the reverse camera have you tried entering the test mode for the touchscreen to see if the camera is showing a picture regardless of weather it's in reverse gear. There is a write up of how to enter the test mode using the 753 hack on the WIKI pages, at least that will narrow down if your getting a picture or not. Regards Jon MY2007 S/C - Stornoway / Jet
Post #129110 3rd Jul 2012 9:04am
highfellzippy
7 days in dealer and counting Tune in tomorrow for an update
the saga continues 7 days in dealer and counting
still no rear camera and dvd showing wrong input
thanks chaps
for all the help
WILL NAME AND SHAME ON HERE THE DEALER ON FRIDAY !!
Post #129211 3rd Jul 2012 3:35pm
Re: 7 days in dealer and counting Tune in tomorrow for an up
hang on a minute, is it not the conversion peeps that caused this problem not the dealer... ... - .- -.
Post #129214 3rd Jul 2012 3:39pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
Indeed, TV in Motion is not a standard fit either..... I know what my dealer would say Rolling with laughter Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #129215 3rd Jul 2012 3:44pm
highfellzippy
What ever the problem is the so called dealer should have a answer for me by now i dont think the conversion affected it but its a possibility
they just keep saying we have checked the plugs and blah Censored blah
going to try another dealer in Lancashire next
Sheep
Post #129217 3rd Jul 2012 3:46pm
JustinP
United Kingdom 2006 Range Rover Vogue SE Supercharged Java Black
Have you or a previous owner fitted TV in-motion, or is the TV working when driving due to corrupt CCF?
Have you confirmed whether the rear camera is working using diagnostic '753' menu yet?
Does anything happen when you select reverse? i.e. the screen goes black?
Can you see the selected transmission gear on the 4x4 screen? (i believe from memory its displayed)
Gone - Range Rover Supercharged 2006
Post #129272 3rd Jul 2012 8:51pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
Jpickie wrote:
...it puts the DVD player into NTSC mode...
Quote:
...normal PAL mode again...
I think you've got that backwards.
mate.
Laughing
Back when I worked in TV, I learned what those acronyms meant:
NTSC = Never The Same Color
PAL = Pale And Lurid Jim
2000 NAS HSE
2005 NAS HSE
Post #129279 3rd Jul 2012 9:43pm
SteveMFr
Site Sponsor
You forgot the French SECAM = System Essentially Contrary to American Method
Razz
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #129281 3rd Jul 2012 10:01pm
Stephen.125
2017 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
@Jim & Steve Laughing
For tv in motion lead if it's a 2006 I.e. pre terrain selector the integrated head unit is under the dash roughly where the dash speaker is. I'm reading this on my iPhone so sorry if yours is >56 plate.
Edit don't suppose it could be an unplugged MOST cable? Does the car kit work?
Post #129290 4th Jul 2012 7:29am
SteveMFr
Site Sponsor
It won't be an unplugged MOST fiber - if the loop is not closed MOST won't work. That is why all units on the MOST bus have 2 fiber connectors.
As for the location, see below. Not all products are exactly the same, though. Depends on who's lead you have.
From http://www.toysinyourcar.com/acatalog/rng_2005on_tvim.html
Plug and Play TV In Motion lead for:
2005 On Range Rover
PLEASE NOTE this is NOT compatible with Land Rover Discovery 3 or Range Rover Sport - see our other leads for those vehicles.
Plug and play installation with full instructions provided.
Connects to IHU unit which is behind screen or lower glove box (2007).
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #129303 4th Jul 2012 9:34am
