Home > Technical (L322) > Where can I get spacers ? |
J.Seven Member Since: 28 Aug 2011 Location: Estoril Posts: 29 |
Want to put spacers on my TD6. Where can I get it and which size are available ? J.Seven |
8th Sep 2011 9:25pm |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35265 |
ebay, about £185 http://www.ebay.co.uk/itm/Terrafirma-Range...335d711266 |
8th Sep 2011 9:34pm |
Thanks. Anyway 30mm seems a little to much, I don't want the wheels to stick out the arches. Does Land Rover sell spacers for these cars? J.Seven |
9th Sep 2011 1:47pm |
not as far as i know..... |
9th Sep 2011 1:52pm |
duckworthparts Site Sponsor Member Since: 30 Jun 2011 Location: Market Rasen, Lincolnshire Posts: 5217 |
definately don't do any genuine spacers. You can paypal direct using - www.paypal.me/duckworthparts
9th Sep 2011 1:53pm |
Spacers will cause extra stress on wheel bearings and other suspension components |
9th Sep 2011 2:30pm |
Alistair Member Since: 11 Feb 2011 Location: Peterborough / Bordeaux / Andorra Posts: 7923 |
Down to nuts being to short or the spacers themselved ? I would have thought that if you changed to longer nuts to compensate for the spacer then there shouldn't be a problem. Happy to be corrected though...... |
9th Sep 2011 8:14pm |
the spacers are bolted onto the hub using new smaller nuts and using the existing stud holes...that leaves the spacer studs for the wheel to locate onto and be 'nutted'..
9th Sep 2011 9:11pm |
rmackinnon Member Since: 14 Mar 2012 Location: Mansfield, UK Posts: 85 |
Does anyone have a photo of their L322 with these on before and after? FFRR 2003 Vogue V8 |
30th Jun 2012 9:52pm |
The Brains Trust Member Since: 23 Sep 2011 Location: Melbourne Posts: 155 |
I wouldn't touch them for the reasons mentioned already - extra stresses on the wheel bearings, and wheels falling off - which is probably why they are completely illegal over here. |
1st Jul 2012 9:52am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
I know this sounds like ganging up on a fairly innocent post but I can't for the life of me see why you would fit spacers , the standard wheel offset is correct for the vehicle putting these thing in put a ( very ) week link in the drive train and at the same time increase the load to the same drive train whilst simultaneously changing the steering geometry increasing bump and torque steer . So all round a bad idea . 2008 MY Supercharged
1st Jul 2012 10:56am |
i can see where the attraction is , the rears on the range seem to not fill out the arch properly so fitting 30mm spacer would make it look better..as for strain on the wheel bits/drivetrain etc , i cant see that as the range is very well built.. ... - .- -.
1st Jul 2012 11:06am |
verydisco Member Since: 10 Dec 2009 Location: UK/US Posts: 2952 |
Not a fan on a road-car (ok on a dedicated offroader I guess)
1st Jul 2012 12:05pm |
wheels with a bigger offset and rim width do look better on the rears but to wide on the fronts, hence the spacers on the rear idea.. ... - .- -.
1st Jul 2012 2:56pm |
