Home > Technical (L322) > 4.4 v8 engine management light
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
i have a 2004 l322 4.4 v8 last few days my engine management light has came on a few times
i have cleared the fault with my rsw allcomms kit but after8-10 miles it comes back on the faults are as follows
Lambda control adaption exceeds lower limit bank 1. Last occurrence - maximum signal
Lambda control adaption exceeds lower limit bank 2. Last occurrence - maximum signal
THE RR IS LPG CONVERTED, RUNS AND STARTS FINE,drives great
ARE THE Lambda sensors faulty
any ideas thanks everyone 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #128196 28th Jun 2012 4:28pm
klf400
this sounds like air to fuel mismatch, the amount of air entering the engine is greater than what is passing the maf sensor ,check if you have any air/vacuum leaks
make sure the large black air duct that runs from the air filter to the throttle housing on the inlet manifold is secure as these do come adrift when replacing the air filter .
also check the pcv valve pipes at the rear of the engine as these collapse and go all goey Thumbs Up 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #128214 28th Jun 2012 5:45pm
STEVE57
hi klf400
will check the pipes etc as you suggest
thanks
steve 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #128260 28th Jun 2012 8:16pm
STEVE57
pcv valve pipes
hi
does anyone have a picture / drawing to show where the pcv valve is located, with the pipes
thanks
Post #128364 29th Jun 2012 12:26pm
might be shown in RAVE [download link in wiki] ... - .- -.
Post #128367 29th Jun 2012 12:33pm
STEVE57
hi stan
found it using "search"
thanks 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #128369 29th Jun 2012 12:40pm
Is it LPG'd?
Post #128403 29th Jun 2012 3:15pm
Dolphinboy
Yes it is Gaz
Post #128409 29th Jun 2012 4:14pm
Very common fault codes on V8 Petrol LPG RR's.
Very difficult to get a permanent cure but I think it the oxygen sensors detecting weak or strong mixture in the exhaust gasses.
Probably needs a bit of tweaking.
Gary
Post #128414 29th Jun 2012 4:39pm
STEVE57
HI ALL
checked the two top pcv pipes and they are soft and rotton, one has a slight split, going to get two new pcv breather pipes from dealer, unable to find alternative supplier,
will keep you updated i will take a picture of the old rotton breather pipes, and post it here
thanks
all 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #128458 29th Jun 2012 6:46pm
klf400
steve
there are 4 pipes to change , 2 large pipes 1 short smaller pipe that goes on the oil seperator and oil tube and the last 1 a long small pipe from the pcv valve to the inlet manifold, they all go rotten and gooey
also for peace of mind i would change the pcv valve
check this out
http://www.rswsolutions.com/index.php?opti...;Itemid=78 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #128465 29th Jun 2012 7:09pm
STEVE57
only the two top pipes are gooey. the other ones are ok 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #128466 29th Jun 2012 7:12pm
klf400
okay fair enough but they are small and can become blocked, but do click on the link i posted the pcv valve is very important and must be working properly 1990 3.5 v8 defender
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #128467 29th Jun 2012 7:31pm
KARMANN
2002 Range Rover Vogue 4.4 V8 Java Black
Any updates on these pipes? How did you get on, problem cured? Ive had a similar issue-engine light is on. i keep clearing it then it returns within 10 miles. It has been running fine until today. I noticed when stationary the engine feels ever so slightly lumpy-and i mean very slightly. I did notice that when the big viscous fan kicks in the enine doesnt feel as lumpy.
I replaced the two o2 sensors infront of the cats recently to cure the engine light as the fault codes pointed towards them. but the light still comes on. Any help much appreciated.
Fraser
Post #136374 16th Aug 2012 10:57pm
STEVE57
UPDATE
HI
REPLACED the two top pcv pipes as they were soft and perrished, one has a was split, got two new pcv breather pipes from dealer, now all ok 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #136419 17th Aug 2012 8:18am
