![]() | Home > Technical (L322) > 4.4 v8 engine management light |
klf400 Member Since: 10 Sep 2011 Location: forest of dean Posts: 210 ![]() ![]() ![]() |
this sounds like air to fuel mismatch, the amount of air entering the engine is greater than what is passing the maf sensor ,check if you have any air/vacuum leaks
STEVE57 Member Since: 26 Apr 2012 Location: solihull Posts: 103 ![]() ![]() ![]() |
hi klf400
hi
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35487 ![]() ![]() |
might be shown in RAVE [download link in wiki] ... - .- -.
hi stan
Is it LPG'd? |
Yes it is Gaz |
Very common fault codes on V8 Petrol LPG RR's.
HI ALL
steve
only the two top pipes are gooey. the other ones are ok 2007 supercharged ,Cairns Blue with Navy & Parchment Interior |
okay fair enough but they are small and can become blocked, but do click on the link i posted the pcv valve is very important and must be working properly 1990 3.5 v8 defender
KARMANN Member Since: 13 Dec 2010 Location: Scotland Posts: 95 ![]() ![]() |
Any updates on these pipes? How did you get on, problem cured? Ive had a similar issue-engine light is on. i keep clearing it then it returns within 10 miles. It has been running fine until today. I noticed when stationary the engine feels ever so slightly lumpy-and i mean very slightly. I did notice that when the big viscous fan kicks in the enine doesnt feel as lumpy.
HI
