![]() | Home > Maintenance & Mods (L322) > Squeaky Rear Suspension |
It throws the rear tracking out and scrubs the tyres |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7877 ![]() ![]() ![]() |
Thought so.
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1426 ![]() ![]() |
Do the generic bush push-puller kits work on the hub bushes? V8 or else ... |
Not sure what you mean by generic bush puller. They need to be heavy duty as the bushes can be a b |
Something like this sort of kit ...which has bits from about 30mm diameter upto about 80mm diameter:
Should be ok, but I would suggest you buy a length of threaded rod and some nuts before you start as the ones in the set will most likely get stripped |
Sets like that look to be @ £300 on the bay.
I've seen a version of that kit for about £150 from a Manchester online place who I'll phone later in the week as it says stock is due in.
I used a Saab bush tool for the bottom bush and a couple of sockets for the top one |
Video of how to make a bush puller/pusher (Landy man!)
