Home > Maintenance & Mods (L322) > Squeaky Rear Suspension
It throws the rear tracking out and scrubs the tyres
Post #128129 28th Jun 2012 1:45pm
mjdronfield
Thought so.
Will arrange to get sorted..........
Take it you don't have to do all the other bushes as well ? Just the pairs of ones that are jiggered ?
Thanks
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #128132 28th Jun 2012 1:55pm
There is a top and bottom bush that should be done at the same time. Wishbone bushes don't usually give much problems so should be fine, but worth checking whilst the vehicle is dismantled. The bottom bush will require a new circlip and you should purchase new camber bolts and fit them before having the tracking done. One camber bolt for the top rose bush and one for the toe control arm per side
Post #128150 28th Jun 2012 2:52pm
fisha
Do the generic bush push-puller kits work on the hub bushes? V8 or else ...
Post #128264 28th Jun 2012 9:19pm
Not sure what you mean by generic bush puller. They need to be heavy duty as the bushes can be a bCensoredd to come out
Post #128269 28th Jun 2012 9:32pm
fisha
Something like this sort of kit ...which has bits from about 30mm diameter upto about 80mm diameter:
 V8 or else ...
Post #128273 28th Jun 2012 10:14pm
Should be ok, but I would suggest you buy a length of threaded rod and some nuts before you start as the ones in the set will most likely get stripped
Post #128293 29th Jun 2012 8:04am
Sets like that look to be @ �300 on the bay.
We need a tool pool for kit like this.
I am hoping I can do the smaller bushes with sockets and threaded rod, but might have to get something made up to replace the subframe bushes! .
Post #128334 29th Jun 2012 11:18am
fisha
I've seen a version of that kit for about �150 from a Manchester online place who I'll phone later in the week as it says stock is due in.
To be honest, the cost of that kit is probably pushing the cost of labour for a full set of bushes too ... Plus it's something that will be able to be used on other cars . The wife has said just get it and be done. A lot of the kits look the same ... Hard to tell from looking at the pics which are quality and which aren't.
As for pool of tools:
I also plan on doing the subframe bushes that the body sits on. This will be a tool that I'm going to make myself from various bits of steel as its essentially a large push puller. If it works well, I'll certainly make it available to other folk to use. Don't be expecting snap-on quality but it should be decent enough. V8 or else ...
Post #128457 29th Jun 2012 7:32pm
I used a Saab bush tool for the bottom bush and a couple of sockets for the top one
Post #128500 29th Jun 2012 11:19pm
Video of how to make a bush puller/pusher (Landy man!)
&feature=watch_response .
Post #128572 30th Jun 2012 11:38am
