Home > Technical (L322) > First unhappy post |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
sounds like the engine was running to lean,was it getting hot or pinking ..did you have the conversion done..now there is a second hand engine on ebay the other day at around 1500 pounds
8th Jun 2012 8:29pm |
PAT COBRA Member Since: 04 Feb 2011 Location: harrow Posts: 2 |
Thanks daveo but that was a BMW 540 so thought a little over priced as could get the whole car for less . Can anyone tell me for certain if a 540 BMW engine is a straight swap if I change the sump , or is it far more involved ? Has anyone done this swap as I still cant find a lump . I also cant find out what the secondary air valve fault is !! |
26th Jun 2012 8:14pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Pat not 100% sure as I don't have the secondary air valve. Have you located it yet? If not its the pipe running at the front of the engine connecting both banks, it has a bolt holding it to the water pump. There is a NRV to the left hand side. The system also has an air pump under the air filter. It is used to create a 2ndry burn in the exhaust manifold for unburnt fuel for emissions. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
26th Jun 2012 11:31pm |
The BMW will work though most of the ancillaries and the sump will need to be swapped. There is a thread on this somewhere - either here or at RR.net.
27th Jun 2012 8:40am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7829 |
I'd keep as much as possible from your original engine, and only use whats broken on the original from the BMW unit.
27th Jun 2012 9:38am |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
extra oil pumps?
29th Jun 2012 12:42am |
