Home > Technical (L322) > First unhappy post
PAT COBRA
2002 Range Rover Vogue 4.4 V8 Epsom Green
First unhappy post
Hi all this is my first post so will try and keep it short . I have 2002 Vogue 4.4 petrol with L.P.G. and I keep getting a fault code saying Faulty Secondary Air Valve and nobody can tell me what this is can anybody on here help please ? My second problem is somewhat bigger , while doing about 80ish sorry 70mph on the M25 in L.P.G. it developed a bad misfire. I had it towed home and it now has zero compression on three pots even putting oil down the bores !!! Can anyone tell me how much I may have to pay for a second hand or new lump and point me in the right direction to get one please . Thanks PAT Big Cry Big Cry Big Cry Big Cry Big Cry
Post #125426 8th Jun 2012 8:18pm
daveo
sounds like the engine was running to lean,was it getting hot or pinking ..did you have the conversion done..now there is a second hand engine on ebay the other day at around 1500 pounds
http://www.ebay.co.uk/itm/RANGE-ROVER-L322..._500wt_950
can be seen running, V8 facelift Range Rover Autobiography 22" wheels.
Post #125429 8th Jun 2012 8:29pm
PAT COBRA
Thanks daveo but that was a BMW 540 so thought a little over priced as could get the whole car for less . Can anyone tell me for certain if a 540 BMW engine is a straight swap if I change the sump , or is it far more involved ? Has anyone done this swap as I still cant find a lump . I also cant find out what the secondary air valve fault is !!
Post #127841 26th Jun 2012 8:14pm
Pat not 100% sure as I don't have the secondary air valve. Have you located it yet? If not its the pipe running at the front of the engine connecting both banks, it has a bolt holding it to the water pump. There is a NRV to the left hand side. The system also has an air pump under the air filter. It is used to create a 2ndry burn in the exhaust manifold for unburnt fuel for emissions. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #127896 26th Jun 2012 11:31pm
SteveMFr
Site Sponsor
The BMW will work though most of the ancillaries and the sump will need to be swapped. There is a thread on this somewhere - either here or at RR.net.
RRC 2Dr, RRC 4Dr,
P38, and 2 L322s
Post #127908 27th Jun 2012 8:40am
mjdronfield
I'd keep as much as possible from your original engine, and only use whats broken on the original from the BMW unit.
Just my 2p.
I have no experience of the swap, but to be on the safe side.........
I know there are baffles in the sump, and extra oil pumps and stuff...........
Smile 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #127915 27th Jun 2012 9:38am
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
extra oil pumps?
no. Just 1, down in the sump. The P38 oil pump is mounted on the engine front cover.
The sump is deeper to allow a larger total volume of oil, and the pickup is positioned so that it won't suck air when the vehicle is at an angle only a Range Rover can achieve.
Also, the front right-hand driveshaft passes through the sump. Jim
2000 NAS HSE
2005 NAS HSE
Post #128290 29th Jun 2012 12:42am
