![]() | Home > Maintenance & Mods (L322) > air suspension and door card help |
andyw Member Since: 15 Oct 2009 Location: united kingdom Posts: 160 ![]() ![]() ![]() |
hi
speedymarktd6 Member Since: 20 Nov 2008 Location: Worcestershire Posts: 727 ![]() ![]() ![]() |
how do you know its the pump ?
i agree that if nothing else EAS should be left to the dealers as there are so many varables and faults to think about
BrianC Member Since: 15 Apr 2009 Location: central belt Posts: 1429 ![]() ![]() |
thanks for the help do i need to worry about the air bag in the door when removing the door card |
well just spent all night replacing my caravan tow socket and passanger window switch panel (as it had pealed)
the air bag is bolted to the door metal and what your doing will not require its removal however i had no ignition key in and was mind full but i had no worries and i took mine off |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1519 ![]() ![]() |
Hey, +1 on the dealer diagnostics... That said if it's got a new compressor and it's still raising slowly check all the pipework, particularly return pipes/collector pipes.
well this started to bug me again so i got it checked over today ,the computer still says brush core temp to high (199)
