Home > Technical (L322) > Christmas tree dash, clunk and misc annoyances! |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35371 |
kinda thinking it would be best to go back to the garage and let them sort it.. ... - .- -.
17th Jun 2012 7:34pm |
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 |
Sounds like the steering angle sensor needs re calibrating. HDC uses the ABS to work. If the car thinks its going left but wheel speeds say no a straight line they confuse the ECUs and go into fail safe mode. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
17th Jun 2012 7:39pm |
benjj Member Since: 27 Feb 2012 Location: North Yorkshire Posts: 116 |
Hmm, thanks chaps. I wonder if this is related:
17th Jun 2012 7:49pm |
Sounds likely that you had the wheel off centre and when the tracking was done they put the steering wheel straight ahead and then track the car. This will cause the steering angle sensor to be out. The default before causing problems is around 11 degrees but if you have moved the steering wheel by 20 degrees your steering angle sensor will be well out. What you will need to do now is find where the sensor is centred and then align the steering wheel to that position and then the tracking will have to be redone |
17th Jun 2012 8:02pm |
Thanks, that makes a lot of sense!
17th Jun 2012 8:32pm |
You need to have the angle sensor set on a computer so that it is straight ahead, then straighten the steering wheel, then have 4 wheel tracking done |
17th Jun 2012 8:48pm |
Magic, will get that done pronto. I just hope that my indy's Autologic is man enough to interrogate and reset the angle sensor... |
17th Jun 2012 8:56pm |
If he has Autologic for the Range Rover that will be perfect |
17th Jun 2012 9:13pm |
He certainly does, my car is on it like a drip
17th Jun 2012 9:14pm |
Update:
18th Jun 2012 11:33am |
It's a common problem, usually after having tracking or suspension work done.
18th Jun 2012 12:02pm |
Just an(other) update on this as it came back!
22nd Jun 2012 8:09am |
