Home > Technical (L322) > Is pulling the plug(s) a good idea??
Saint.v8
Location: UK< Surrey - Near the Middle Close to Some Green Bits
United Kingdom 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Hi all,
First time post, please be gentle..!!
I have a 2003 4.4 Vogue on Gas, had it now 2 weeks and loving it, bar the odd niggle - ABS sensor failure and when I had LR recalibrate the ride height, a couple of days later the EAS went inactive....LR read and cleared the fault on the NSR Height Sensor which we have put down to lack of use as the previous owner had the ride height calibrated 2.75" lower than normal, so when I asked for it to be corrected, they reckon the upper portion of the senor was a bit cruddy and the recal upset things.....that was 12 days ago, so fingies crossed all is well....
On to the Q.....
The well documented Steering wheel drive motor(s) failure.....
Looking to reduce component failure, so if I can stop the system from retracting and extending each time the ignition is turned on or off etc, I feel it would be beneficial....
If I just pull the two plugs to the motors (C1394 and C1395) would this be a solution or will it throw up a fault or two??
Or is there a software way of doing this....??
I am saving the pennies at the end of the month to get hold of the All Comms from RSW (Funds can't stretch to Hawkeye or Faultmate Extreme just yet), does the All Comms have the ability to switch this function off?
Many thanks in advance for your advice,
Ant.
Post #125993 13th Jun 2012 4:24pm
welcome to the forum..
rover all comms can switch the steering column off , i've done this and have had no problems..
your signature's a bit big mind... Wink ... - .- -.
Post #126015 13th Jun 2012 5:19pm
Saint.v8
Many thanks for your reply....glad to hear the All Comms will do the trick....
Signature resized!! Very Happy
Post #126066 13th Jun 2012 8:58pm
Thumbs Up ... - .- -.
Post #126068 13th Jun 2012 8:59pm
Jonno
United Kingdom 2012 Range Rover Autobiography 5.0 SC V8 Causeway Grey
Welcome,
You can just set the steering wheel to where you want it to be then unplug the two motors. It won't throw up any faults (well it didn't on mine anyway Very Happy )
Jonno 5.0 supercharged autobiography
Gone-4.4 Vogue Lpg now unmapped
4.6 HSET Turbo Lpg mapped
Gone-Defender 90 200tdi
Gone - 3.9 Sprintex supercharged LPG
Gone - 3.9 Vogue LPG
Post #126069 13th Jun 2012 9:04pm
Saint.v8
stan wrote:
All Comms Ordered.... Mr. Green
Post #126071 13th Jun 2012 9:17pm
Saint.v8
Jonno wrote:
Welcome,
Jonno
That was my original plan, but if the short-one (the girlfriend) gets the opportunity to drive it, the faf to replug it in takes the edge of the solution....
As above, All Comms ordered from the genius that is Storey Wilson Very Happy
Post #126072 13th Jun 2012 9:18pm
Dolphinboy
Welcome saint. I know you are going to be soooooo glad you made the change up from P38. The boys on here are much more helpful than the .... Ahem, other site! Enjoy your V8!
Ps have you had your LPG serviced yet?
Post #126075 13th Jun 2012 9:33pm
Jonno
easy solution...............Don't let her drive it Laughing 5.0 supercharged autobiography
Post #126076 13th Jun 2012 9:37pm
Saint.v8
Hi DB,
Yes seems more L322 biased than the 'Other Site' so with luck will be a vaulable asset in the arsenal, and I hope to be a productive member too....
Very Happy
Post #126078 13th Jun 2012 9:42pm
Saint.v8
She did let me buy it, so would be kind of wrong to say no....but that would be the ultimate solution, and cheaper too!!
Post #126079 13th Jun 2012 9:43pm
hoppy
England 2003 Range Rover Vogue 4.4 V8 Adriatic Blue
Saint.v8 wrote:
cant go wrong with it mate....
excellent piece of kit....... Thumbs Up free use of "RSW" all comms to anyone nearby
Post #126120 14th Jun 2012 9:26am
JW911
The easiest way is to motor the steering wheel into the dash as far as it will go, then adjust the seat so you can reach. The column never needs to move then. 2021 3.0 P400 Vogue - coming!
2012 4.4 TDV8 Westminster - going!
2007 3.6 TDV8 Vogue - gone!
2003 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #126125 14th Jun 2012 10:15am
Nothing like disabling features that make the cars special and a Range Rover.... Surprised
Post #126155 14th Jun 2012 1:15pm
