Home > Technical (L322) > Sub Woofer Vibration |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Hi
7th Feb 2010 1:26pm |
robbo770 Member Since: 10 Jan 2010 Location: Aberdeenshire Posts: 467 |
go in via the passenger door rear, pull the upholstered trim up at an angle as it has pushin clips and an hook retainer in the side panel to keep it in tight to the side bulk head, it will not come completely of as it is fix at the top.
7th Feb 2010 1:30pm |
Trying that , i assume you mean the leather wrapped panel next to the rear seat?
7th Feb 2010 1:42pm |
fold seats , yes, remove entry plate, lower rear plastic arch cover, this allows you good leverage to pull up and out on the panel you mentioned,
7th Feb 2010 1:52pm |
Sorry last one , entry plate? What part is this? CURRENT : FFRR 2012 4.4 TDV8
7th Feb 2010 1:59pm |
floor alliminum carpet edge plate, give good even pull upwards as its held in with 2 push fit clips, carefull when removed as these slide and you need to realign for reinstall, to the sockets in the floor, thats it. |
7th Feb 2010 2:02pm |
Cheers Robbo - job Done! CURRENT : FFRR 2012 4.4 TDV8
7th Feb 2010 2:31pm |
my current wiring project from the intravee has made me find the easiest path for wiring etc, and thats what I did!!
7th Feb 2010 2:56pm |
God damn it,
7th Feb 2010 5:53pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6361 |
Have you checked the fuse for the sub? Just a thought.
7th Feb 2010 6:27pm |
