Home > Maintenance & Mods (L322) > Got new style flip key to work..!
Page 7 of 9 <123456789>
daveo
ok thats all five now gone, yes you can use you old key but you have to be careful not to make it to short as it will rub on the trim around the ignition. V8 facelift Range Rover Autobiography 22" wheels.
Post #125826 12th Jun 2012 3:23pm
daveo
hi, blanks are in and i will post out, please make payment... V8 facelift Range Rover Autobiography 22" wheels.
Post #126383 15th Jun 2012 6:21pm
robbo770
Scotland 2005 Range Rover Supercharged 4.2 SC V8 Zambezi Silver
cheers Dave, thanks for getting a source of the blank for everyone. Current vehicles
4.2 SC FFRR RSE 2010- facelift
Range Rover Evogue Dynamic Lux
Gone
Rejected RRS my14.5 nightmare
Disco B4 XXV convert
Freelander 06 SE
06 RFFRR 4.2 SC Vogue RSE
Audi A8 4.2Tdi Quattro (hated with a vengence!!)
54 FFRR 2005 model V8 4.4 Cobra Variant
53 Mitsubishi Shogun V6
Post #127147 21st Jun 2012 3:40pm
robbo770
I called Timpsons Head ofice and explained I wished to have a blank cut at my own risk at a local branch, customer service was very helpful, contacted the branch and they agreed to cut it for me at my risk.
thus a phone call makes getting it cut easy, Current vehicles
Gone
Freelander 06 SE
Post #129410 4th Jul 2012 3:20pm
robbo770
well, got the manager to program a Timpson T4 chip for me at the same time, so key cut plus a spare blade and coded chip for £40.
got home and made the timpson chip fit with the coil nearest the ingnition, left it in the car running for about 2 hours to charge.
carried out Daves guide to program in all my keys and ha presto!!! I have a working flip key.
fantastic, thanks Dave for the supply of the blank , I now have a spare as I also made a original spare blank fit!.
dremel out the chrome key ring hole a bit as was more like a camera strap slot that a key ring holder!!!!
super Thumbs Up Thumbs Up Thumbs Up Current vehicles
Gone
Freelander 06 SE
Post #129424 4th Jul 2012 4:14pm
ebajema
Dave, you're right about the blade, if cut too short it rubs. Mine is only just clear. Still can't use it to open and close the doors though, despite the fact that I have it on the North American frequency. Sad MY 2010 5.0 SC Galway green and sand interior!!
Post #129453 4th Jul 2012 7:58pm
robbo770
sounds like you need to let it charge up with the engine running with it in the ignition, at least 2 hours, then follow daves programming steps. Current vehicles
Gone
Freelander 06 SE
Post #129454 4th Jul 2012 8:00pm
mattstevenson2005
United Kingdom 2003 Range Rover Autobiography 4.4 V8 Java Black
i have my new flip key all cut and assembled, programmed it in the car and it opens and closes the doors fine but wont start the car, i have put the original transponder from my old spare key into the new flip key - the car starts fine with my original old style key and if i then try and attempt to start the car with the flip key it works and starts the car fine but if i try and start the car with the flip key after opening the car with it, it will not start?? any ideas??
Matt
Post #129692 6th Jul 2012 3:48pm
Flashman
England 2011 Range Rover Autobiography TDV8 Santorini Black
The transponder ship is very sensitive and needs to be as close to the edge of the fob as possible, even a few mm difference cause the car to lock up if not in the right position. There should be a slot to perfectly match the transponder chip and keep it in place on the fob under the rubber inlay.
You can hear the car unlock the steering column when the chip is in the correct position before you even turn the key. Tom
Current Drive
2011 4.4 TDV8 Autobiography - Santorini Black - Ivory Leather
Previous Drives
2004 Model Vogue Td6 (Touchscreen) - Java Black - Parchment Leather
1994 RR Classic 3.9 V8 Soft dash - Niagara Grey - Grey Leather
1972 Series III SWB Safari - Green (Hand Painted) - Black Plastic
Post #129710 6th Jul 2012 4:22pm
robbo770
the chip is also directional, so ensure you fit it in exactly the same orentation as the original key, you can prove it by just holding the chip near the ingnition hole area, you will hear the unlock of the barrel to allow turning.
try the key in both sides, as mine was tight to begin with in one way, but has now bedded in and works both ways smoothly.
cheers Rob Current vehicles
Gone
Freelander 06 SE
Post #129717 6th Jul 2012 4:54pm
daveo
robbo, so how did they program your chip, i was told that it had to be programmed with the car.. V8 facelift Range Rover Autobiography 22" wheels.
Post #129719 6th Jul 2012 4:59pm
robbo770
the Timpson T4X chip I bought to allow me to keep my original key as a spare as well,
The Key chip was programmed in their machine and then via the car with my original key, then saved on their machine again.
works a charm, well worth the £40 for the chip and cutting of 2 blanks.
I have keep the blank from yourself as an emergency backup.
I then as stated ran the car with the new fob in it for about 2 hours and then programmed all keys.
worked first time.
I did not use the original key chip but it unlocks the barrel by just inserting it near the top of the barrel, so can't see why Flashman is having the issue described as if the chip works in his original should work on its own as the fob has nothing to do with unlocking of the barrel, the code is only on the chip.
Gone
Freelander 06 SE
Post #129724 6th Jul 2012 5:13pm
daveo
so did there chip fit into the new key ok... V8 facelift Range Rover Autobiography 22" wheels.
Post #129738 6th Jul 2012 6:11pm
robbo770
I had to remove the support that acts as the stop for the slot for the land rover shaped one under the rubber inner slave.
This also had the square stop removed as their one is about half a length longer in a 3 mm dia glass tube.
This then presses into the rubber inner sleeve when the case is put together, holding it suggly,
Remember visible coil nearest the key when flipped out to go into the ignition.
Thanks Rob Current vehicles
Gone
Freelander 06 SE
Post #129740 6th Jul 2012 7:05pm
mattstevenson2005
do you mean timpson the key cutting shops? it is starting to look like the new flip key has some how fried my original transponder chip as it wont even work back in the original landrover key anymore (it worked perfectly this afternoon no problems)
matt
Post #129747 6th Jul 2012 7:58pm
