Home > Maintenance & Mods (L322) > Service costs |
TheAllSeeingPie Member Since: 18 Apr 2012 Location: Leeds Posts: 848 |
Oil service was £480 for me at a main dealer. The track rod end, brakes and others bits pushed the bill to about £1400 though.
10th Jun 2012 5:02pm |
Nick Ground Member Since: 27 Dec 2011 Location: Dorset Posts: 584 |
I have had a similar experience. Oil service looks like reasonable value at main dealer to maintain the stamps, then they find the extras! Brake discs are considered sacrificial now so with the Brembo brakes expect a complete set of disks at under 30k miles.
10th Jun 2012 6:32pm |
stenh02 Member Since: 30 Jan 2011 Location: Somewhere not warm Posts: 341 |
You could consider registering in your local LR dealers Allegiance Scheme (for LR's older than 3 years) which saves 20% on service costs, parts etc and supply your own oil which also saves a bit. Forum sponsor Opie does good deals on oil.
10th Jun 2012 8:13pm |
Fortunately I knew my brakes were (scored on the back and worn pads on the front) so it wasn't a massive surprise. They also put in a new sidelight bulb and cleaned the car as well as knocking 20% off parts and rebalancing my wheels. So overall the service was really good and knowing they are close to work and very accommodating is good.
10th Jun 2012 8:53pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8486 |
Good quality discs and pads can be had for quite a reasonable cost, it may be worth taking care of these type of things outside the dealer network and restricting them to simply the basic service and stamping the book.
11th Jun 2012 9:00pm |
daveo Member Since: 21 Oct 2009 Location: london Posts: 2307 |
i went in to the dealers and asked for 8 plugs and an oil filter, i do all my servicing my self as i fill the dealers are way to high,i find if you have a local garage tat know his stuff you are better of going there.i get my oil from work..castrol fully synthetic and always buy genuin parts, any way he put them down and said £200 odd quid, i said how much off you are joking, £19 EACH, i phoned BMW they do the same plugs for £69.00 V8 facelift Range Rover Autobiography 22" wheels.
11th Jun 2012 9:19pm |
Mine is going in to the dealers for its service on Thursday ... |
11th Jun 2012 9:25pm |
well i hope you dont need a set of plugs.. V8 facelift Range Rover Autobiography 22" wheels.
11th Jun 2012 9:30pm |
Lloyd Barnes Member Since: 21 Apr 2011 Location: Shrewsbury Posts: 181 |
That sounds interesting. I'm more than happy to swap out brakes etc myself ( in fact it needs some pads now as they squeal like a piggy at traffic jam speeds... V embarrassing ) I would if possible like to keep the LR stamp though. I'll check out the Allegiance Scheme. Do all the dealers do that? Think our local one would be Shukers Shrewsbury. Thanks for the advice. Lloyd Barnes Current Crendon 427 Sideoiler Cobra in build... 7 litres of madness! Gone 2008 TDV8 Vogue - Black with Ivory/Grand Black Lacquer 2008 VW Touareg 3.0Tdi 6.3litre Dax Cobra - 12.34 Second 1/4mile at 114mph |
12th Jun 2012 6:32pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
i remember the good old days when i used to shell out for spark plugs for my Disco's....
12th Jun 2012 6:58pm |
The scheme seems to be run thru dealerships and you get a personalised card and acces to a web page which details your car and services you have purchased.
12th Jun 2012 7:38pm |
my local dealer doesn't run any kind of schemes!! i think it is because they are an independant company and choose not to. the other nearest dealership is a branch of Stratstones and they do. so i think it is very much up to the dealerships. Current: TDV8 (3.6) RRS HSE
12th Jun 2012 8:05pm |
Had a root about on the net and Shukers do do an Allegiance Scheme so I've applied for that. First though some new pads. Anyone got any recommendations for where to get pads that don't do an impression of Deliverance? Lloyd Barnes
12th Jun 2012 8:30pm |
you could try these places, eurospares have 30% off at the moment!!
13th Jun 2012 5:35am |
