Home > Technical (L322) > Funny buzzing?
Funny buzzing?
I have had what can omly be described as a Funny buzzing noise from drivers side footwell.
I had just engaged low ratio as i was parking on a steep hill. And i then got this quite loud buzzing.
It carried on after i had turned off the ignition and removed the key, and slowly faded out, it didnt return when i switched it back on.
Weird, but no idea what it was.
Any ideas? There is nothing that can't be fixed with a hammer😜😜
Post #124840 3rd Jun 2012 4:53pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
My 4.4 and my 4.2 and my 5.0 and my 3.6 have all done this - it's the sounder for the front parking sensors sometimes that goes all odd, but other times it's a fan that decides to have an off day. Nothing to worry about as usually sorts itself. If it seemed to fade out I'd say it was the sensor speaker having a funny turn Smile Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #124843 3rd Jun 2012 5:21pm
Thought it sounded speakeresque it sounded like a capacitor fading out.
Cheers for the reply. There is nothing that can't be fixed with a hammer😜😜
Post #124844 3rd Jun 2012 5:25pm
stu
can i just be a bit blonde and ask why you were in low ratio??? Current: TDV8 (3.6) RRS HSE
Past: TDV8(4.4) Vogue
Discovery 3 Commercial
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #125436 9th Jun 2012 6:51am
Because he was parked on a steep hill...
Pulling away up said steep hill Doesn't stress/overheat/burn the oil/gearbox components as much...
Craig Thumbs Up
Post #125443 9th Jun 2012 8:17am
mjdronfield
If the brakes fail, the car will hold on the transmission at a steeper angle before it rolls.
Its harder for the weight of the car to turn the engine over when its not running.
Not sure how this works as well on an auto though........will the torque converter not slip anyway ? - and why you can't bump start autos ? Interesting.........
Mark
EDIT - Craig's just answered about driving on a steep hill. I assumed he was parking on it, and leaving his car. maybe I'm wrong. 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #125444 9th Jun 2012 8:19am
stu
i did read and fully understand the original post, but there is no reason to put in low ratio just because it is on a steep hill!!
sorry for going off topic, but just thought i'd ask the question. Current: TDV8 (3.6) RRS HSE
TDV8(3.6) Vogue
TD6 Vogue
D2 V8 ES
D1 V8 ES
RR Vogue Classic
Post #125467 9th Jun 2012 12:13pm
I had it in low ratio as i was trying to get into a tight paralell parking space and as i was on a hill it wouldnt "creep" up the hill in hi ratio.
It was a bit easier to put it in low and let the car creep into the space and not have to press the gas. Cool
Buzzing went away, yet to return. There is nothing that can't be fixed with a hammer😜😜
Post #125539 10th Jun 2012 7:23am
