Home > Technical (L322) > Funny buzzing? |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
My 4.4 and my 4.2 and my 5.0 and my 3.6 have all done this - it's the sounder for the front parking sensors sometimes that goes all odd, but other times it's a fan that decides to have an off day. Nothing to worry about as usually sorts itself. If it seemed to fade out I'd say it was the sensor speaker having a funny turn Land Rover Addict
3rd Jun 2012 5:21pm |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8632 |
Thought it sounded speakeresque it sounded like a capacitor fading out.
3rd Jun 2012 5:25pm |
stu Member Since: 04 May 2011 Location: Richmond North Yorkshire Posts: 927 |
can i just be a bit blonde and ask why you were in low ratio??? Current: TDV8 (3.6) RRS HSE
9th Jun 2012 6:51am |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16298 |
Because he was parked on a steep hill... Pulling away up said steep hill Doesn't stress/overheat/burn the oil/gearbox components as much... Craig Last edited by Cam-Tech-Craig on 9th Jun 2012 8:29am. Edited 1 time in total |
9th Jun 2012 8:17am |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7818 |
If the brakes fail, the car will hold on the transmission at a steeper angle before it rolls.
9th Jun 2012 8:19am |
i did read and fully understand the original post, but there is no reason to put in low ratio just because it is on a steep hill!!
9th Jun 2012 12:13pm |
I had it in low ratio as i was trying to get into a tight paralell parking space and as i was on a hill it wouldnt "creep" up the hill in hi ratio.
10th Jun 2012 7:23am |
