Home > Technical (L322) > heater hose |
It will need to be drained to below the level of the lowest hose |
1st Jun 2012 3:18pm |
snugg Member Since: 16 Jun 2010 Location: Maryland Posts: 29 |
How does lowering the coolant level under the lowest hose keeps the air out of the system. When the new hoses are installed they will have air in them. IF I fill the overfull tank and bleeding the system with the bleed screw, will that provide enough head to push the air out of the total system? |
1st Jun 2012 3:44pm |
It doesn't, it will however stop coolant spilling all over the road/driveway/pavement/sidewalk (delete as necessary)
1st Jun 2012 3:55pm |
Thanks 47p2!!! That's similar to what I was thinking. |
1st Jun 2012 4:01pm |
Once up to temp rev the engine to around 2000rpm to allow the water pump to circulate the water round the engine |
1st Jun 2012 4:03pm |
Got it. Thanks |
1st Jun 2012 4:21pm |
jim2RRs Member Since: 07 Feb 2012 Location: Genesee, Colorado Posts: 147 |
you'll only dump about a quart replacing those 3 hoses.
1st Jun 2012 6:53pm |
No harm in dumping the lot and refilling with fresh coolant |
1st Jun 2012 8:35pm |
