Home > Technical (L322) > heater hose
snugg
United States 2008 Range Rover HSE 4.4 V8 Stornoway Grey
heater hose
Will I have to drain the coolant system to replace the 3 heater hoses at the rear of the engine bay coming from the fire wall (drivers side US spec). My concern is air getting into the system will I am replacing the hoses.
Post #124669 1st Jun 2012 3:14pm
It will need to be drained to below the level of the lowest hose
Post #124671 1st Jun 2012 3:18pm
snugg
How does lowering the coolant level under the lowest hose keeps the air out of the system. When the new hoses are installed they will have air in them. IF I fill the overfull tank and bleeding the system with the bleed screw, will that provide enough head to push the air out of the total system?
Post #124674 1st Jun 2012 3:44pm
It doesn't, it will however stop coolant spilling all over the road/driveway/pavement/sidewalk (delete as necessary)
You will have to bleed the system once you have fitted the new hoses.
Usual procedure is to fit hoses and fill the system with coolant, (leave the cap off the expansion bottle for now) open the bleed screw and allow a constant flow before closing the bleed screw, (still keep the cap off the expansion bottle) set heater blower and temperature to maximum heat and run engine until it is up to temperature then open the bleed screw to expel any air and top up the expansion bottle, fit the cap, job done
Post #124676 1st Jun 2012 3:55pm
snugg
Thanks 47p2!!! That's similar to what I was thinking.
Post #124678 1st Jun 2012 4:01pm
Once up to temp rev the engine to around 2000rpm to allow the water pump to circulate the water round the engine
Post #124679 1st Jun 2012 4:03pm
snugg
Got it. Thanks
Post #124681 1st Jun 2012 4:21pm
jim2RRs
United States 2005 Range Rover HSE 4.4 V8 Chawton White
you'll only dump about a quart replacing those 3 hoses.
trying to catch it is the impossible part.
siphon it out of the expansion tank, maybe?
i put a oil-change basin thing under mine, that got most of it. Jim
2000 NAS HSE
2005 NAS HSE
Post #124702 1st Jun 2012 6:53pm
No harm in dumping the lot and refilling with fresh coolant Thumbs Up
Post #124717 1st Jun 2012 8:35pm
