Home > Technical (L322) > PDC - Ahhhhh more problems |
Vogue Owner Member Since: 12 Jun 2008 Location: Braintree Posts: 234 |
Has anyone had problems with their Park Distance Control going wrong.
7th Nov 2008 10:53am |
axle Member Since: 28 Oct 2007 Location: Perth Perth the end of the Earth Posts: 2964 |
Mine some times give up and then come back after a re-boot seems to be if you select reverse too soon after starting the engine. Once happened after heavy rain as well but al is OK now. 2008 MY Supercharged
7th Nov 2008 12:02pm |
Axle - what do you mean by a reboot? is this something i can do or is it a factory reboot |
7th Nov 2008 12:04pm |
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6370 |
When a sensor goes wrong the system gives an auditory beep to alert the driver. Simple way to check is to switch ignition on, put sensors on and get someone to put a hand in front of each sensor at a time, then you'll know which one is duff.
7th Nov 2008 2:57pm |
Vogue Owner by re-boot I just mean switch off to half an hour then re start, but I still find selecting reverce to soon will give it a dose of the sullks . 2008 MY Supercharged
7th Nov 2008 3:08pm |
Axle - yes you are very correct - putting it into reverse as soon as you start up has caused quite a few issues - one in particular was the suspension problem i had on Wednesday where the ride height was set on access mode.
7th Nov 2008 5:07pm |
