Home > LPG > air suspension pump relocation due to lpg tank install
klf400
any one got any pictures of the air suspension pump relocation after lpg install
just doing mine and it seems impossible to keep the pump within its tortoise shell to fit it down with the tank
so looking for some ideas , i do have a plan but it would be good to see some other conversions Smile 1990 3.5 v8 defender
2000 4.6 v8 30th anniversary prins lpg
2004 4.4 v8 vogue prins lpg
2011 4.4 TDV8 Vogue
faultmate extreme
rsw allcoms
Autel 906BT
Gap iiD tool
Post #124254 29th May 2012 9:15pm
fisha
The shell can come off leaving the bits inside to be mounted on their own V8 or else ...
Post #124273 29th May 2012 10:08pm
Some people relocate it to the drivers side boot cubby - where the detachable tow bar lives / fuse box is. .
Post #124285 29th May 2012 10:50pm
Ive got one compressor in the cubby box on the right and one in the spare wheel well. both locations req the tortoise shell to be removed. [img]http://www.fuelly.com/driver/rob2529/range-rover[img/]
Post #124287 29th May 2012 11:01pm
STEVE57
England 2007 Range Rover Supercharged 4.2 SC V8 Cairns Blue
GOT MINE IN the drivers side boot cubby, without the tortise shell 2007 supercharged ,Cairns Blue with Navy & Parchment Interior
Post #124298 29th May 2012 11:43pm
bozmandb9
2013 Range Rover Vogue SE TDV8 Causeway Grey
You can 'modify' the shell to fit back in on top of the tank, I'm sure you'll find pictures in the forum if you search. Cam Tech Craig did it on the car he bought from me, and I did it on my second conversion! 2012 SDV8 Vogue SE
Post #124300 29th May 2012 11:51pm
tsadpt
I fitted a Preston air kit a couple of weeks back. Well engineered and quiet. Seems expensive, but worth it I think.
Post #124375 30th May 2012 4:34pm
