Home > Maintenance & Mods (L322) > Visit to gearbox specialist this week, any questions? |
Bellini Member Since: 11 Jan 2012 Location: Berkshire Posts: 2261 |
Going to basics, how often do they recommend the gearbox oil be replaced? Mileage-wise and time-wise.
29th May 2012 8:18am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35419 |
......is it possible for us to reset the 'adaptive' part of the gearbox... ... - .- -.
29th May 2012 8:49am |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6410 |
Have they come across a situation where the transfer box motor works OK (even tried this with a brand new motor), and will put the box into low range, but refuses to put the box back into high range, causing TRANS FAILSAFE error messages. Only way to get back into high range is to manually wind it back with an old motor. All wiring checks out (have tested). This on TD6 '02 with GM box.
29th May 2012 9:36am |
Simes Member Since: 30 Aug 2011 Location: Hinckley Posts: 964 |
1. Is there a God? Supplementary questions: If there is, why does he let gearboxes fail? If there isn't, who on earth invented the torque converter? |
29th May 2012 10:02am |
Stephen.125 Member Since: 25 Jun 2009 Location: Frodsham Posts: 1518 |
How much wood would a woo... never mind...
29th May 2012 10:04am |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1393 |
Ask them what size of oil cooler would be needed if the heat exchanger was removed and a cooler used instead. V8 or else ... |
29th May 2012 7:35pm |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1020 |
Stan, In short the answer is yes, I know because when they reflash the gearbox software they have to do so before installing the new file. However it can be a high risk strategy, with my car, the adaptations were effectively making it work, it had learned how to work despite being badly worn. As soon as the adaptations were reset, I had to get it rebuilt! Range Rover-less at the moment - Pining! |
30th May 2012 1:49pm |
..but is it possible for 'us' to do it...
30th May 2012 2:01pm |
Ignition not on - Switch off - then back onto just the auxiliary position... Not ignition on.
30th May 2012 2:31pm |
i know the proper procedure as described in another thread, i was just doing an 'etc,etc,etc' for it.. ... - .- -.
30th May 2012 3:07pm |
VaguelyVogue Member Since: 05 Feb 2010 Location: Buckinghamshire Posts: 380 |
Are they going to flush the gearbox ? |
30th May 2012 5:03pm |
Cam-Tech-Craig Member Since: 03 Aug 2011 Location: Gloucestershire Posts: 16302 |
Well, been today and they have checked mine over and have flushed the hole gearbox system, on a machine that gets all the oil out and flushes through some form of cleaning agent. It also flushes the cooler as it acts like a second larger filter and gradually clogs with crap leading too all sorts of issues... They updated the software and checked all the ECU's for fault codes...
30th May 2012 7:40pm |
CG-SC Member Since: 06 May 2011 Location: Falkirk Posts: 528 |
What did they charge you for the oil change ? Stolen / Gone: 2006MY Supercharged LPG Autobiography - Zambezi Silver with Sand/Jet/Jet Oxford Leather..... |
30th May 2012 8:02pm |
£200 for everything at a trade rate...
30th May 2012 8:11pm |
