Home > Technical (L322) > Gear ratio table
fairwx
2015 Range Rover Vogue SE SDV6 Luxor
Gear ratio table
Can anyone point me to where I can find a gear ratio table for the high and low range gearbox currently in the MY12 4.4 V8 Diesel?
The owners handbook is quite useless, with no mention of ratios in the technical spec chapter.
Thanks
Post #123776 26th May 2012 8:40pm
Paul J.
You can work it out if you drive at, say, 40mph in 6th, read what the RPM is, then repeat in low range. Divide one by the other, and you have the ratio.
Paul
Post #123777 26th May 2012 8:55pm
RRPhil
The ZF 8HP70 has a ratio spread of 7.05 and the following ratios :
1st = 4.71
2nd = 3.14
3rd = 2.11
4th = 1.67
5th = 1.29
6th = 1.00
7th = 0.84
8th = 0.67
Rev. = -3.32
It’s mated to the same Magna Steyr DD295 transfer box used for the 6-speed transmissions which has a 2.93:1 low range with direct (1:1) high.
I believe that the axle ratio was lengthened from the old 3.54 to 2.76 for the 4.4 TDV8 so, assuming a dynamic tyre rolling radius of 377mm, the maximum overdrive ratio will be 48mph/1000rpm
Phil
Post #123789 26th May 2012 10:48pm
fairwx
Thanks Phil. Useful to know what they mated the ZF 8spd to.
Post #123796 26th May 2012 11:31pm
mjdronfield
Here we go mate,
Better late than never......
I looked when you first posted, and thought I only had data for the 3.6 Diesel....
The info you want is the rightmost column, from the 40th anniversary guide.....
Mark 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #124815 3rd Jun 2012 10:27am
fairwx
Fantastic thanks!
Post #125430 8th Jun 2012 10:24pm
