Home > Technical (L322) > Suspension fault after change of battery
Elena
United Kingdom 2006 Range Rover Vogue Td6 Java Black
Hi everyone
I recently changed my battery and since then the Suspension Fault warning comes on periodically but the suspension works fine when the different height settings are used. When the battery was removed we noticed a that a black connector wasn't connected at all but when we put the new battery in we made sure that this black connector was connected. The error message has been coming on since but not all the time and doesn't stay on. I hope someone can help with this.
Kind regards
Elena
Post #123671 25th May 2012 9:10pm
DMRR
South Africa 2009 Range Rover Westminster TDV8 Stornoway Grey
It is possible that you have reconnected the transit system. After delivery they disconnect this and leave it loose in the compartment..... Land Rover Addict
XXXXXXXXXXXXXXXXXXXXXXX
Previous
XXXXXXXXXXXXXXXX
2009 5.0V8SC Autobiography
2006 4.2V8SC Autobiography
2004 4.4V8 Vogue
Post #123672 25th May 2012 9:30pm
Elena
Hi, thank you for that I will disconnect it and see how it goes.
Regards
Elena
Post #123673 25th May 2012 9:38pm
woodchopper23
United Kingdom 2010 Range Rover Vogue TDV8 Ipanema Sand
Have you turned the steering wheels fully left , then fully right after reconnecting the battery? You get faults coming up if you do not do this. MY2010 TDV8 Vogue Ipanema Sand
2002 V8 Vogue Oslo Blue - Gone.
Post #123715 26th May 2012 9:32am
^^^^ +1 ... - .- -.
Post #123719 26th May 2012 9:46am
Elena
When you say turn the steering wheel left then right is this with the engine running?
Post #123735 26th May 2012 12:04pm
in the wiki, http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
Post #123740 26th May 2012 12:15pm
woodchopper23
Yes MY2010 TDV8 Vogue Ipanema Sand
Post #123744 26th May 2012 1:24pm
