Home > Technical (L322) > Suspension fault after change of battery |
DMRR Member Since: 14 Apr 2010 Location: Northamptonshire Posts: 2027 |
It is possible that you have reconnected the transit system. After delivery they disconnect this and leave it loose in the compartment..... Land Rover Addict
25th May 2012 8:30pm |
Elena Member Since: 10 May 2012 Location: Coventry Posts: 42 |
Hi, thank you for that I will disconnect it and see how it goes.
25th May 2012 8:38pm |
woodchopper23 Member Since: 20 Jan 2012 Location: cumbria Posts: 259 |
Have you turned the steering wheels fully left , then fully right after reconnecting the battery? You get faults coming up if you do not do this. MY2010 TDV8 Vogue Ipanema Sand
26th May 2012 8:32am |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35286 |
^^^^ +1 ... - .- -.
26th May 2012 8:46am |
When you say turn the steering wheel left then right is this with the engine running? |
26th May 2012 11:04am |
in the wiki, http://www.fullfatrr.com/wiki/Battery_dis-connection_procedure ... - .- -.
26th May 2012 11:15am |
Yes MY2010 TDV8 Vogue Ipanema Sand
26th May 2012 12:24pm |
