![]() | Home > Maintenance & Mods (L322) > Tdv8 gearbox again |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3866 ![]() ![]() ![]() |
So it's doing it more often now, going into neutral before picking up again after a quick slowdown particularly with some lock on - roundabouts! The IIDTool actually says up down switching fault whatever that is. It does seem to clear and drive normally although interestingly Sport mode can't be selected - you can move the stick across but the car stays in drive. This actually fixes itself after a restart - needless to say dealer can't replicate - anyone had similar or got any ideas Geoff |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35483 ![]() ![]() |
there's another member who found his gearbox pump had gone, could this be your problem geoff... ... - .- -.
Stan,
Oy that's my post not Stans on the Wiki |
And again ![]() |
appropriate credit put on wiki post.... |
sleepezy Member Since: 22 Feb 2010 Location: Cambridgeshire Posts: 185 ![]() ![]() ![]() |
Also having similar issues (no prizes for guessing the mileage...)
Well I found the gearbox and after at first trying this fix with my long arms and a mirror - couldn't fit my fat frame under the car- I nipped round to a mates house who has trolley jack and axle stands and got going with the WD40 followed by Lithium grease. He knows stuff and says not to use copper grease on linkages, I don't know stuff so slapped on the general purpose Lithium based grease I took round.
jinkytoby Member Since: 22 Sep 2011 Location: padstow Posts: 9 ![]() |
nice to know it aint just the td6 box thats made of cheese ( just a joke) bit like all the range rover gearboxes |
Jury is of course still out on this fix but as it costs virtually nothing and takes 10 minutes it falls into the category of preventative maintenance.
It would seem that the problem I had with the car dropping into neutral for a second when slowing, turning and accelerating I.e. roundabouts where you don't stop or bends on winding roads is fixed thanks to this site and the wiki that suggests lubricating and greasing the linkage on the side of the auto box.
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8680 ![]() ![]() ![]() |
Might be worth asking garages to lube it up as a matter of course during any service. ShOuld be cheap... There is nothing that can't be fixed with a hammer😜😜
Just picked my car up from the garage having had this issue fixed.
All good |
