![]() | Home > Technical (L322) > Help its pinging at me |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3785 ![]() ![]() |
dodgy battery? |
Polux Member Since: 02 Jun 2009 Location: UK Posts: 242 ![]() ![]() |
would a dodgy battery stop the key in the iginition from turning??? |
not sure to be honest, the starter switch is so complicated. Think mine went like this when the battery went US a while back - despite small levels of power being left in the battery. Also the starter frequently doesn't connect if you jump in and turn it too quickly - ecu brain not overiding the imobiliser probably.
RRUK Site Supporter Member Since: 08 Jun 2007 Location: UK Posts: 6373 ![]() ![]() ![]() |
Yes double check its properly in Park and your foot is on the brake pedal.
well yup it was the battery replace cost �79 however now car alarm does not work so took it into Gorden lamb chesterfield and they say it will cost �45 to resync key to alarm. does this sound feasable?
Sounds feasible for a Dealer to say that yes....is it cost effective for what they actually do? Probably not, but what choice do you have? Discovery 4 HSE
Polux Is your RR petrol or diesel as that battery sounds very reasonable. If it was a diesel do you know what the make and spec was?? many battery dealers tried to palm me off with lower spec batteries than OEM standard and these came out at the �70 to �80 mark, their AH was significantly lower.
No, you can do it yourself I believe. Some combination of buttons and key turns within a certain amount of time.... Info is in the WSM ![]() |
whats the WSM?? and where do you get it. |
its a petrol, just bought an (platinum) oem which had the same spec as the one plugged out a the original fac fitted varta. + �10 to fit by 2 of my local servce guys and omg was it a job took em half an hour what a stupid design setup. |
Every signal from the remote handset contains the transmitter identification code and a rolling code. The BCU checks the codes and only responds if the signal is from a valid transmitter. During vehicle production, the remote handsets supplied with the vehicle are initialised to set their individual transmitter identification codes and synchronise their respective rolling codes with the BCU. If a transmitter loses synchronisation with the BCU, or if a replacement or additional remote handset is to be used with the vehicle, the initialisation procedure must be repeated. During the procedure, all remote handsets for use with the vehicle must be initialised.
I looked in Rave and couldn't find anything, where did you find that nugget? Discovery 4 HSE
Polux, this is the Batt I got, they recommended this for all FFRR...
I did a search in Rave, although knew it was there as I read the whole thing from cover to cover before I bought the L322 (geek). I think it was in the "Security" section, search for "Initialisation" Dan ![]() |
